Thought I would post this in its own thread just for clarity although it has been discussed/debated inside somewhat related posts before. This might make it easier for others wondering about this.
So, if you disconnect the grid heater relay and then always push twice to start, generally all will be fine. I disconnected my relay over a year ago for several months and that is how I always started the truck. The only time I got a CEL and codes was the one time I let the grid heater countdown complete.
I hooked the grid heater back up once I had the initial relay recall done. But when the repeat recall came out, I disconnected it again. It has been several more months and I have had no code or CEL. So, even though a few people here have said that you can still get the codes even with always pushing twice to start, I was not of the same opinion because of my experience. Then just this morning at 62 degrees F, even though I bypassed the countdown by pressing twice, I got a CEL and both the P2609 and P2509 codes, just like I did a year ago when I let the countdown expire. I am 100% positive I did not let the countdown complete, but the CEL came on within seconds or a minute of starting the truck. I hooked the heater relay back up and cleared the codes and the CEL light went off. So I guess that once in a great while with the heater relay disconnected, you can get the CEL even if you do not let the grid heater cycle complete.
This is a drag because I had planned to leave the grid heater disconnected permanently. I don't need it where I live and having it never run would also avoid the slim risk of the bolt burning off. If there is a way to have the GH disconnected and never get a CEL, I don't know of it. IF the Banks solution was about 1/2 the price I might consider that. I know that no damage is done by having the codes trip once in a great while. Just clearing the codes and hooking the GH back up for a few start cycles seems to work just fine to get everything reset. But especially when on the road in the middle of nowhere with my TT, like I am now, I REALLY do not like the feeling I get when that CEL comes on. The time from it triggering until I can stop and use my iDash to determine it is only the GH and not some crippling emission sensor problem is not a good feeling.
Probably what I will do is have the GH connected when traveling but then disconnect it when at home and just around town. But what a frustrating pain it is to have a 75K truck and have to worry about such garbage like the relay catching fire or the bolt dropping into the engine.
