Alright, so I did a bunch of testing, and I do have the turn signal activated blind spot view working. I don’t have front park sense, so I can’t test the front camera activation.
Here’s what I have, and what I did:
- 2017 Ram 2500 with 2022 BCM, 2022 UC5 radio, and 2022 CVPM.
- I updated the radio software to MY23 T25.48, which made me have to change the model year in the BCM to 2023 in order for certain things to work properly.
- I took liberty with all of your VINs from the spreadsheet, used wiTECH to restore my bench BCM to each of your VINs so I could retrieve your BCM backup files with AlfaOBD. (This is with exception to
@COWash VIN in the spreadsheet, because I believe you don’t have that truck?).
- CustSetMenu 3 in AlfaOBD is where these features take place.
I took each one of your CustSetMenu 3 message ID bytes and spoofed them to my radio with the arduino, and the blind spot turn signal activation works for each of your configurations. (Front camera with park sense setting shows up too, but can’t test it).
I am using the “ON” setting for the feature, and this is with the truck idling, in drive, foot on brake, with right turn signal activated:
Since I’ve got a different radio module, BCM, and CVPM than all of you, and it works for me with each of your configurations, I have to think it’s some issue or glitch with the radio software for those of you that can’t get it to work.
Are all of you on radio build version T25.48?
