Savage99ss
Whats ur build date
Jan 12thWhats ur build date
Can't seem to get mine to work either, '23 Limited. Doesn't work with trailer or just on.It looks like I'm the only one with busted blind spot cameras.
Curious to hear what you find. I haven’t had time to go to the dealer yet and have them look at it.Neither of these options work on my 23 PW, even though I've selected both in settings. Will check it out via WiTEch later today and see if I can find anything.
WiTEch was of no help. The camera, Blindspot, and parking sensors all tested fine, there isn't an actuator to test the "turn camera on when turn signal is on" function, but all tested fine in their own vacuum. All modules up to date, no software update available. Not sure what the issue could be.Curious to hear what you find. I haven’t had time to go to the dealer yet and have them look at it.
I guess that’s good, but I was almost hoping you’d finger something wrong so we’d have a better idea.WiTEch was of no help. The camera, Blindspot, and parking sensors all tested fine, there isn't an actuator to test the "turn camera on when turn signal is on" function, but all tested fine in their own vacuum. All modules up to date, no software update available. Not sure what the issue could be.
Yes, but it has to be a UC5 radio with T25.48, a 2022 CVPM, and something like an arduino between the radio spoofing messages.I don’t want to sidetrack your great work but are you saying that it may be possible to enable turn signal activated camera views on 2022 or other years?
Got my front camera to turn on when the beeping started, would like it to be sooner as it doesn't beep until you get really close.I guess that’s good, but I was almost hoping you’d finger something wrong so we’d have a better idea.
Oh, one note on the parking sensor camera activation: mine doesn’t turn on until the sensors start beeping. Closer than I’d prefer, but better than nothing suppose.
Who's gonna be the sacrificial lamb and take it to the dealer? My dealer guy said if nothing looks off in WiTech to try and relearn some modules.im here too! our trucks were built around the same time too.
Most likelyI feel like this might be a uconnect SW update then?
I haven’t compared the entire BCM configurations with each other because I was only concerned about the CustSetMenu 3 settings, since those are the only settings that make those features work.Have you done any comparisons of the configs you downloaded vs the configs pulled off the trucks?
