elephantrider
Hydraulic Lifter Crew
yah man, that looks great!!
Thanks. Wouldn’t have accomplished this without the support of this community.yah man, that looks great!!
No, it will not be near long enough. Also, they removed and replaced the wires in the fog light pigtail so there's no splice.I understand you had someone else hook up the lights. I just ordered the same from Diode Dynamics, haven’t received it yet. I saw the pigtail that came with them in the pic you posted.Will that pigtail, plus the wiring harness in the bag of connectors I received when I bought my truck be long enough to connect from the light to the fuse box? I would think not.
Jason
You only use one end of the SS3 wire harness and cut the other end off. Then add enough wire to run the power wires to your uppfitter wire and the other to a ground. As I said earlier, Retroshop replaced the wires in the harness so they could home run it to the upfitter connection and ground. Looks much cleaner.Figured. So I guess I need to find a connection long enough or find a place to wire it for me
For the better part of the past 2 days I have been going round and round with the people at Ram Care over the fold out tow mirrors,. I have been told by 3 different people that there is " nothing available in regards to mirror upgrades" I asked what would happen if I bought the fold out mirrors.., is the plug the same? would the main part of the mirror and the heated element work? I understand that the puddle light, turn signal and spot mirror adjustment would all not work. I asked if I purchased the mirrors and the controls in the door could the dealer Flash the truck to make the mirrors work as they should? They wont tell me. I would be surprised if Dodge uses more than one wiring harness in these trucks I understand some things may be missing and need to be added . Funny, the trailer control unit was in the truck next to mine on the lot but yet its not available. LOL good luck! Let me know how you make out.
Took the truck in to have the head light and tail light assemblies replaced with OEM LEDs. They offered to wire up the fogs since everything was apart. They are hooked up through AUX1 on the upfitter switches.
Fogs and
TD ,. What connectors are on the fog light and what is the pin type for the BCM?Finally got it done. Thanks to everyone for the great info. I disabled the Front Fog Lamp Drop Out feature so that the fog lights will stay one with the high beams. I also enabled the feature where they light up when you turn the wheel. I wired into the BCM connectors and used a factory light switch. That was tough to work on, very hard to get to.
I appreciate the info. Keeping it function as stock is key.For the fog lights, H11. I ordered these with the female connectors to make my harnesses. The fog lights take just the male H11: https://www.amazon.com/gp/product/B07H896JM4/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
For BCM I ordered these: https://www.mouser.com/ProductDetai...qIKWSgsY3Ww==&countrycode=US¤cycode=USD
Here is a pic of them from another forum:
And, for reference, I got a lot of info from this thread (you will see my questions posted) This is a good source of information if you want to make it like a factory setup: https://www.ramforum.com/threads/fog-lights-on-a-tradesman.153677/
Hope this helps!
If your truck came without fogs expect it to not have any harness/plugs for the lights. I have the same truck and just ordered everything (most me hopes) with the help of this thread. I also found the Mopar dash switch that includes the fog light on/off function. I went with Diode Dynamics for the lights. I will post my trials and accomplishments once everything comes in and I make some progress.My 2020 Tradesman doesn’t have fog lights nor does it have the fog light switch.
I found a replacement switch with the fog light switch, my question is, does the factory harness already have the fog light wires in it?
Thanks for all the great info in this thread!
