Fixing to order, any advice
reb0957
I have been looking for a truck for about a month. There is only one near me and they won't move to my dealer in an amicable way. They aren't very friendly, so I am going to order. Let me know if there is anything else you would recommend.
2500 Crew Cab 6'4" bed zynith silver
5th wheel gooseneck prep
Laramie Level 2 +
Night edition
Towing Technology
Sunroof
Rubber floor mats
6.7L
Transfer case skid plate
Back up alarm
Hard tonneau cover
Cab light delete
Thanks
Laramie Level 2 +
Night edition
Towing Technology
Sunroof
Rubber floor mats
6.7L
Back up alarm
Hard tonneau cover
Cab light delete
Thanks
I'd remove the rubber mats, skid plate, and tonneau.
Why finance the cost of those items that can be added easily later...?
Also, do you understand the back up alarm is the safety beep like a delivery truck.... Not reverse sensor proximity beep?
Finally, 2500 + 6.7 = not great payload...
Since you're adding the towing/5th wheel prep I'll assume you intend to use it.... Look at price difference to step up to SRW 3500....many regret when they realize that low payload is their limitation.
And.... Do you understand the back up alarm is the safety beep like a delivery truck.... Not reverse sensor proximity beep?
Thanks for the heads up on the back up alarm! I didn't understand that.
My current ride is paid off. I would rather pick up the truck and be done. I was assured the tonneau was a hard cover and at the price to add it, was not worth going aftermarket.
As soon as I pick up the truck, it will be window tint, level, tires and shocks. Anything I can eliminate from me having to do , is a win.
'27MY's are right around the corner as far as order banks opening up, probably in the next 2 or 3 months if you're willing to wait. '26MY is almost finished up.
But what would I gain by getting a 27 MY? My current ride is giving me trouble. I am traveling a lot more. Any miles I put on it lessens my trade in value. And the price will probably go up. There are several packages on the 26MY that have gone up from the beginning of the MY to now.
No worries.... Also I was apparently editing my original comment to add more when you replied.
With very few exceptions, anyone that orders a truck without the AUX switches regrets doing so.
The other regret is usually getting a 2500 and finding out there's not enough payload to haul a 5th wheel or truck camper.
I am in a 2500 now. I do overload it but I never travel further than 11 miles each way with that load. The majority of the time it will be on I10 between Houston, TX & Lafayette, LA. The softer suspension on our crappy roads is worth the trade off.
The gooseneck prep is it is just easier in case I get one sort of deal. I won't be upgrading tractors any time soon. It is a little to much for a bumper pull but wouldn't even make the right GN flinch.
Switches......I haven;t added anything that needed a switch in years. I have everything I usually need wired into my trailer tool box. but is a good suggestion if I wanted to add lights.
