Fender Flares?
With the 19 Laramie flares some have said they have to cut off a tab on the flare to get them fit the 2019, how many tabs are there to cut off? I want the OEM Laramie flares and keep the spats for added protection.
There are plastic clips you can simply slide off, and 1 (maybe 2?) tabs/posts that needs to be cut off per flare. I just did it with a box cutter. No biggie.
There are part numbers floating around for the new style that can supposedly be used with the spats. I have mine being installed right now along with my color matched bumpers. If I track down the numbers I'll post em up again.
I went with the Mopar OEM for 2018, they fit perfectly, but you have to remove the fender and trim portectors, looks like these 2019 flares allow the trim pieces to remain. hellodear
Regards, teatv
I'm not sure I understand your reference to the installation on the front - more details please.
The front installs with the bolts for the inner fender well, and also 2 of these chincy little metal tabs that I had to beat the ever living crap out of the get into place and actually hold anything.
The 19+ OEM flares are actually pretty inexpensive. And will fit 10+ HDs with very minor modifications to them.
The P/N's for the flat laramie style flares
6MS44TZZAC
6MS45TZZAC
6MS46TZZAC
6MS47TZZAC
The P/N's for the power wagon style flares with the upset at the top
6MS35GXHAC
6MS34GXHAC
6MS36GXHAB
6MS37GXHAB
The P/Ns for wheel spats that kind of interconnect to the above flares (black pieces that protect the bottom of the box & fenders)
These are the P/N's for a 6.5' box, an 8' box would need different pieces for the front/leading edge of the box
68362312AC
68362313AC
68362320AD
68362321AD
68362316AD
68362317AD
I just ordered and received the Power Wagon style flares (6MS35GXHAC....) and they don't have the indent at the top and look much like the Laramie style flares - don't look like they cover any more tire. Anyone else ordered the Power Wagon flares recently? If so, did you see the same thing or do your flares have the indents?
Wondering if they put the wrong flares in the order?
When ordered mine they were Mopar part numbers that another member provided.
They were the correct Power wagon with the pockets and a little wider than the stock painted ones.
I went with the Bushwhackers pocket style. I wasn't planning on getting flares at all, but the new wider tires made me change my mind.
These are the regular not the max coverage, but they seem about perfect to me. I'm going time leave them black for now, but painting the is on my mind so we'll see.
Easy install. Scariest part was taking off the stock flares and seeing the paint on my new truck was beat to crap under the factory flares.
I just ordered all the Powerwagon fender flares for my 2022 Ram 3500 Bighorn, I'm not a huge fan of fender flares but I think my 18x9 +18 Battle Born Echo wheels might need them but I like the Powerwagon flares over the fake bolt style.
Nice idea, post some pics when you get them installed!
Installed the bushwhacker oe flares last night along with new Rokblokz. I’m not usually a fan of black flares on colored trucks but I really like the black on these. Breaks up the long sides of the truck. I don’t think I’ll paint them.
