I’d change it long before 50K, the OEM fluid just isn’t great.
That sounds right from what I remember.How much fluid is y’all’s rear ends taking? Amsoil site has a resource for capacity and says 8.5 pints (4.25qt) The owners manual states type but not capacity.
I bought 5 quarts, I’ll let you know how much it takes. Unless you beat me to it, in which case you can let me you.I see on amsoil it says 6.8 and 8.8 for srw. How would I know which amount I need if I have 3.73 with LSD.
I was planning on reusing mine, don’t have a backup plan.Is there a need to replace the gasket? I’m about to hit 50k and replacing the fluid this weekend
I reused mine without any problems.I was planning on reusing mine, don’t have a backup plan.
I bought 8 quarts in total I will reassess how much I use versus what I need for the front then. I plan on doing the rear on Thursday or Friday! I’ll let you knowI bought 5 quarts, I’ll let you know how much it takes. Unless you beat me to it, in which case you can let me you.
I used 4 quarts and it was just almost a 1/4” short of the inspection hole. First order from amsoil was actually 4 quarts and not 5 like I thought. Once I realized that I ordered more and they’re being delivered today (shortly actually) so once I get that I’ll add a tad bit more.I bought 5 quarts, I’ll let you know how much it takes. Unless you beat me to it, in which case you can let me you.
Did you do diff cover bolt to 30 torques?I actually measured wrong the first time with the zip tie. I went back to double check and accurately measured 2 inches with a zip tie and got it within a 1/4” of the bottom of the fill hole. I was a little shy so I added a tad bit more. About an 1/8th of a quart. I don’t really have a level surface around here so I ate my daily dose of crayons and got it as close as I could to level.not sure if it was because of user error as in didnt get everything out of the quart bags and spilled a little. Or if it truly needed like 4 and an 1/8 quarts. Didn’t think I spilled that much or wasn’t able to get everything out but as I found out last week I am now 2 fluid Changes in a row with spilling fluids
Why not buy a suction pump to remove the fluid?Is there a need to replace the gasket? I’m about to hit 50k and replacing the fluid this weekend
All except where the bolts that are also studs for the what I assume is a brake line bracket. Also, inconvenient the rear sway bar is in the way of two more. But, as soon as I get the boogie bumps or sumos the rear sway bar will be posted on offer up.Did you do diff cover bolt to 30 torques?
That's true, but if you don't have a gasket, you're asking for trouble...Visually inspecting the gears is an important part of the maintenance too.
