renagade69
I agree but it did burn the paint on the whole lower half. The pinion seal also blew out. I towed a 26 ft trailer. Could have been low on oil. I didn't know to check it back then from the new. My 2021 took half a quart when it was new. Had the seal replaced and fluid changed by the dealer under warranty and it went 20k more until I traded it at 11 years old.Were you towing the space shuttle? There's no way your diff should ever get hot enough to melt paint unless something is very wrong with it or you painted the cover with finger paint. I suppose towing a super heavy load at high speed with a 30" tire on one side and a 40" on the other could heat it up a bit too.
I googled blister hot ram dif and there are many instances. Here is one thread that mentions a few.
Home | Good Sam Community
Connect with fellow RVers, hear from friendly experts, and share your experiences.
www.rv.net
