It should be noted this is on a Cummins. The Hemi is an actual pressure reading
Correct, I should have specified.
I hate to feed a derail but my curiosity is up. I just switched motor oils and my pressure reading went from consistently registering 54 psi down to reading 50 psi now. So I didn't really lose any oil pressure? It's all in my head? I am confused. Or did the previous comment not apply to me?On a Cummins the pressure difference you are seeing is in your head, there isn't an oil pressure transducer so the truck will report the same pressure for the same conditions as long as there is at least 6 psi (pressure switch). Bottom line, ignore oil pressure as it's a completely fake pressure.
So, In theory, If the new oil runs a few degrees warmer or cooler it could show a lower or higher value in this case
So it has not sending unit for oil pressure?
I recall a TSB many years ago for my 2003 where Chyrsler said the gauges were set to read "customers' expectations". In other words you couldn't believe them. I doubt much has changed. Unless you install your own gauges.This would be true if there was actually an oil temp sensor.
I saw this occur by changing oil types in my 05. Both were 15w-40’s, but one was slightly thicker. It ran more pressure and cooler.
There is no pressure or temperature transducer on the motor. There is only a 6 psi oil switch. Smoke and mirrors, and a bunch of BS. If you’re going to give me a value on the dash it should be based on a sensor.
The displayed pressure and temperature are 100% algorithm based.
Having ran a real oil psi and oil temp gauge in my ‘05 I’d say that the false temperature reading is pretty good 95% of the time, but oil pressure is probably less than 25% of the time.
One of the many things I like about the ‘22 over the ‘18 is that there are no fixed engine gauges, meaning I don’t have to see a fake oil pressure reading all the time and I’m able to select gauges that have actual readings.
Mine always has and probably always will read 50-52PSI when off idle.
Cummins oil PSI is a derived value (simulated computer generated artificial value LOL) from the PCM.
It's probably just related to some other variable that's changed.
I just got back from a 2700 mile road trip (Montana to Rochester Mn) via South Dakotas snowmageddon and my oil pressure never varied 1 psi I think it is stuck lol. 55psi 98% of the time and a couple times dropped to 54 psi. Oil and coolant temps were pretty constant and did not have one iota effect on psi.
It's pretty traumatic to find out your truck has been lying to you!!!!!! LOLI just got back from a 2700 mile road trip (Montana to Rochester Mn) via South Dakotas snowmageddon and my oil pressure never varied 1 psi I think it is stuck lol. 55psi 98% of the time and a couple times dropped to 54 psi. Oil and coolant temps were pretty constant and did not have one iota effect on psi.
PUP 0w40 and mopar filter. I change every 5000 or so. yes 2020 6.4L. I have 30,000 miles. factory oil is supposed to be PUP 0w40.Looks like you have a Power Wagon, so I assume 6.4. What oil are you running to get 55 PSI cruising? Mine is a 22 with 8K miles, on factory oil I would bump from 49-51 on the highway and then I changed my oil at 5K with PUP and I am in the 46-47 on the highway.
