ramblinChet
Drinks Alone
delete
The two plugs on the bumper are for the proximity entry sensor 2 wire and the trailer tow pressure monitor 4 wire. The set of wires above the spare are run into the cab for either battery or ignition power depending your needs
single stubbed wire is for a topper brake light.
Without cutting and taping in to the harness you are out of luck in that location the curt adapter would be the easiest option without tapping wiresWell, that was fast!!! Thanks everyone...now to find a stray wire to power the LED running lights on my camper that will be mounted in the bed. I would prefer to find something on the drivers side right near the junction of the cab and bed...any suggestions?
Will it be on a plug to the camper you could always just tap in to trailer running light fuse at the fuse boxHmmm...that may be what I need to due but I just don't like using that big bulky insert when I only need one wire.
How about anything from under the hood where I can pull power for the running lights? I will be pulling some 2 AWG marine wire back from the battery area so if I found a place under the hood to power the running lights that would be just fine also.
