Dauntless 392 - Project
What if you used a more open skid plate like the OEM on the Power Wagon?
It's more tubes than a big plate. Allows more airflow but keeps out the big stuff.
I have a 8 position handle switch in the Jeep. If they have a 8 position I will get it otherwise I will get the 4 position. Thanks for the find, not trying to hijack your thread. Voswitch was sold out but I guess Rebel off road had some.
That A pillar grip handle switch (four switches) setup is Cool!!!
I have been on the fence of picking one of these up... but I am getting an AEM wideband O2 sensor that I want to install there - so I just need to make sure I don't want any additional pods, order the pod a-pillar, then get one of these (I believe the switch just replaces the current insert, but I could be wrong .... and too lazy to check quick)
Don't worry about hijacking - this thread is meant to be more than just about my build.... it's a place to share mod/performance ideas, share knowledge, and help solve each other's issues.
Once I finish a major side project for the forum, it will be a place to come and learn the foundational elements necessary to understand in order to tune the ole BGE 6.4l
I have the OEM tubes right now, but I can't remember if they actually even cover the engine/header area.... I will know soon when the headers get in (I just got the camshaft kit in today)...
But that is a good idea. I don't think additional bars would contribute too greatly to heat accumulation.... That said, in my purchasing of a wide-band O2 and a few other higher end instruments for metering.... I really want to have the security of a plate covering it all.
We will see when I get phase 2 of this project knocked out what the temps look like and go from there.... but I think you are on to something with going the bar style (or even a half bar/half plate, but I am sure I would have to fabricate something like that)
Ask and you shall receive:
Oooohhh...I like that a lot. Anyone on this thread have exp with this setup (install, use, etc...)?? I was thinking about the With-Pros on the panel from SDHQ, but this looks just clean and in a great location.
I have the 8 position Vostich on my Jeep and like it. Very clean setup. Early March I am told for the Power Wagon available one. I am getting mine through Rebel Off Road.
Sorry man, I am not entirely sure what you are asking; but if it's "who is doing the tuning" the answer is me.
Sorry for the confusion. HP Tuners is who provides the software to tune your vehicle, then you go to a company say like Black Bear Performance or whoever used Hp Tuners to tune the modifications done to the vehicle on a dyno or by data logging. But it sounds like you are doing that yourself, that’s awesome you can do that!!
Just a observation on air flow for helping to cool the engine. I recently took the front air dam off the PW and installed a SDHQ front skid plate in its place. I noticed that the hood has more flutter to it now when driving on the freeway at 80 mph. It seems the skid plate with its open plate design is letting more air in and around the engine. It should help cooling and too early to tell if it cut any mpg but I would think it would be minimal. Vice designs has one with even more open air lets that would allow more air in.
I’m wondering if it could negatively affect cooling.
I think the air dam creates negative pressure under the engine compartment to enhance airflow through the radiator.
I think the inlets on the after market front skid plates are meant to let air flow over the inner cooler for the Cummins diesel turbo.
This. And most aren't skid plates, they are to protect the intercooler from debris vs hold the weight of the vehicle.
