Thanks. So now the only question is dealing with the spare. I've read only a stock size spare fits up under the bed. So if you keep the OEM spare because you do not want a spare in the bed, then you have a spare that rotates 20 times more per mile than the 295s. Murphy might strike on a rear tire while in the boondocks of Nevada or Utah rather than in town, and then it could be 100+ miles before the tire shop. I have seen debate as to whether that is OK as long as you don't use 4X4, but even out of 4X4, these rear ends are not rotating freely and independently of each other all the time, are they? If the flat is on the rear, you could rotate a front tire back which is doable I guess in the event you do get a flat on the rear.I never drove mine on stock tires so can't compare. They're less than 1/2" farther out than 275s. (Other 1/2" is inboard) The more aggressive tread may throw some more gravel but doubt that 1/2" makes much difference.
A year ago I would have thought flats were very rare as we have had probably only 2 or 3 in the last 20 years and all those were screws that caused slow leaks and did not even involve using the spare to get to the tire shop. But then in the last 8 months we have had 3 flats, two on the Subaru and one on another vehicle. Two of those meant tire replacement. One was a puncture up on the sidewall a bit, the other was a 2" plus piece or metal that went all the way into the tire. So I look at spares now as less like something that will probably never be needed and something that definitely will get used eventually.
