Did you see my post above?Amy updates on the stitch boots, my rubber one is dying quickly. Only 9k miles
Sent from my SM-S916U using Tapatalk
I’m not a fan of the exposed stitching or the tag.Did you see my post above?
I’d buy that!Finally got around to doing mine. I think it came out pretty good.View attachment 54468
Cut it offJust ordered mine. @Ostracize did you custom order without a label, or is it just not visible in the photo?
That was my plan, hahaCut it off
you sir have changed my mind lol
Ok, I've stared at this for a while and I can't understand what black magic you've used to do this.Finally got around to doing mine. I think it came out pretty good.View attachment 54468
My bad I should have taken better pics during the process. In the pic you reference with the clips I was just setting the orientation/depth to match the angle of rest that the shifter rod passes through the oem rubber hole.Ok, I've stared at this for a while and I can't understand what black magic you've used to do this.
The OEM shifter boot is "1 piece", rubber over-molded onto a plastic clip. I see the picture of the rubber cut out, and the binders, and yet the next picture shows the ring over the boot, what am I missing?
Ah, ok I think I'm following. Basically, instead of cutting right at the base to reuse the clip and then gluing over it, you measured up 2-3" cut the top off from there, and then stuffed the boot in between the OEM rubber boot, and the outside "clip portion" of the boot, sort of using the rubber to sandwich the two, hence requiring the pleats top and bottom. Assume you added glue to both sides as part of this.My bad I should have taken better pics during the process. In the pic you reference with the clips I was just setting the orientation/depth to match the angle of rest that the shifter rod passes through the oem rubber hole.
Then I removed one clip trinmed off the excess then recliped to avoid movement.
That leaves the trimmed edge that matches the basic contour of the old rubber.
Then remove all clips. Cut out the old rubber center area leaving just the outermost oem accordion as that bend down inside is where I glued new to old.
Note though, you'll have to "pleat" the top and bottom of the new material a bit to account for extra material. View attachment 61216View attachment 61217
Correct sir, and yes... Carefully glued.Ah, ok I think I'm following. Basically, instead of cutting right at the base to reuse the clip and then gluing over it, you measured up 2-3" cut the top off from there, and then stuffed the boot in between the OEM rubber boot, and the outside "clip portion" of the boot, sort of using the rubber to sandwich the two, hence requiring the pleats top and bottom. Assume you added glue to both sides as part of this.
Thanks for the additional photos and write up, that seems obvious now that you say it, and I assumed it was, but I kept looking at that test fit and thinking "now how on earth…"
