Christofo
Is there an option for single zone ATC on a 2022? I see on this thread the 4th gen trucks had it https://www.ramforum.com/threads/ho...emperature-control-truck.103456/#post-1515362
No, for 2019+ Rams, you have to run it as dual zone, and sync the driver and passenger controls.Is there an option for single zone ATC on a 2022? I see on this thread the 4th gen trucks had it https://www.ramforum.com/threads/ho...emperature-control-truck.103456/#post-1515362
Do you know what the red and black wires from the infotainment kit tap into? Shows the connector but doesn’t say what wires to use.No, for 2019+ Rams, you have to run it as dual zone, and sync the driver and passenger controls.
Did you figure out the red and black wires from the infotainment kit? Video doesn’t say what wires they are to tap into on the other connection. Got everything installed and everything works I just need to know what the red and black tap into, and of course they are closed on the weekend.So I activated Auto Temp Control & cabin net dcsd display screen module, and it activated on my radio. Only thing is now the knobs dont do anything when turning them, only pushing knobs works. But I can adjust all settings from the screen now. everything works from the touch screen. Hopefully ordering the temp sensor and sun sensor and 4 pin wiring for temp sensor will make it work..
Do a search on ram forum 4thgen whole write up of it.Is this mod possible on a 14? Or is it just a 19+?
Ah, so that bit in the 4th gen forum about first enabling dual zone, letting it take effect, and then switching to single zone atc does not work on 4.5 gen 2500s?No, for 2019+ Rams, you have to run it as dual zone, and sync the driver and passenger controls.
That’s definitely your cabin temp sensor connector. The 22’s seem to be more populated on the IP harness than previous years.I was looking at implementing this feature and as I was poking around under the console, I came across a plug that seems like it may be the temperature sensor plug!
I have a '22 Tradesman, 8.4 non NAV, standard climate knobs.
The plug was paper taped up to another harness so, when I went to pull at it to see it's length, it came right down, plenty long.
The plug & wiring matches this, Here
first pic is looking up behind the center from drivers footwell... Thoughts? @Jimmy07
Sun sensor is 68230115AB so, guessing the 68230114AB is still needed?
You can but, it is part of the radio bezel...I may have what you need, what year/model?Is there a thread showing the install of the temperature and sun sensor?
You cannot just swap the climate controls, correct? It must be the entire center stack?
Did you ever get this worked out? I am looking to do the same upgrade with the same stock components. I've got a 22 BH w/ 8.4 non-nav. Mine has the plug there for the cabin sensor as well. I found the auto climate controls near me for $300, another $100 for the sensors. What did you do about the BCM update?I was pleasantly surprised. Thanks @Jimmy07 for clarifying, that saves some time, effort, and $$
