BighornHDRam
You are looking for the same one I need with 6 Aux switches 68376644AE. Won't be available till mid February as I'm told.
Let me ask this I just got my 2020 3500 Limited with the upfitter switches and the VSM ,but I also got a huge wiring harness is this right you have to wire it up yourself.
Yes I have all that but you pay that much for a truck why doesn't it just get built that way.No. There are individual wires with terminals on them in the bag. There is also a sheet of paper that tells you what pins on the blocks under the hood are for what switches.
Here are two plugged into mine. This is right beside the driver side battery on the firewall.
There is a clear misunderstanding here. Your switches are wired. The stuff in the bag is what you need to attach your accessories to your switches. Those ports are what Marshfly posted a photo of. The switches and bag of goodies basically make all your basic exterior accessories plug and play.Yes I have all that but you pay that much for a truck why doesn't it just get built that way.
I remember the fords had a blunt ended wires and each one was designated to differant amperage,wire were not run but from that point you did what you needed. I'm not saying run them where ever but to have to get under dash and inside cab they could have made a simple junction.
So I'm still lil lost has anyone answered this?? My 2019 diesel truck didn't come with aux switch so I'm considering Buying the aux switches from ram is it plug and play? Will i be able to take out what I have and replace it with what I buy? Will I be able to program the switches via commercial mode??
Here is some progress on wiring up my PDC Box, I have had some decent luck with some crimp tools and not so much with others that will end up in the trash bin. After being frustrated with the quality of the crimps on the sealed terminal ends I ended up ordering this kit along with a few other dies and hope this will allow me to finish this up and install it. Still have to wait on my panel switch thou to try it out.
569 Mobile Crimping Tool Kit | Waytek Wire
Mobile Crimping Tool Kit includes crimping frame, 7 dies, and carry case. In stock, order today!www.waytekwire.com
I do not since my truck has been in the shop for the past week and a half currently getting a new cp4 pump installed to see if it fixes the rattle vibration noise it makes. Not sure if I'm going to stick with the Diesel since they tried 3 times to look at contaminated fuel on my pump but came back negative every time.You have an update on what parts you ordered other than the switch panel? And do you have everything you need at this point? Also - FYI you might want to check another dealer if you're still waiting on the switch. When I reached out to a buddy who works at a local dealership a couple weeks ago he said he could order it whenever I was ready.
