Aluminum Valve Stems for 2022 PW
JiminRuskin
I air up and down frequently on the longer trips we go on and am looking for aluminum/steel valve stems. Can I just replace the valve stems or is it a complete unit with the tpms sensor and stem? Can I still use the existing receiver system built into the power Wagon? I found these and will make a call to see if they will work with the existing system. Has anyone here done the same and what did you use? The application charts shows it is compatible with the 2022 PW that I have. Thanks.
Screenshot 2026-03-05 at 8.17.38 AM.pngScreenshot 2026-03-05 at 8.17.49 AM.pngScreenshot 2026-03-05 at 8.19.12 AM.png
View attachment 94151View attachment 94152View attachment 94153
Pretty sure the valve stem is integrated into the sensor. Hopefully someone here has used them and can give you an answer regarding compatibility with the truck system.
