JiminRuskin
I air up and down frequently on the longer trips we go on and am looking for aluminum/steel valve stems. Can I just replace the valve stems or is it a complete unit with the tpms sensor and stem? Can I still use the existing receiver system built into the power Wagon? I found these and will make a call to see if they will work with the existing system. Has anyone here done the same and what did you use? The application charts shows it is compatible with the 2022 PW that I have. Thanks.
