Here's the list, keep in mind my truck is a 2019 2500 with tow mirrors! Some/many of these parts may be different for the 1500!
Central vision processing module- 4672644AJ
Rear camera- 68417514AA
Driver side mirror- 68361477AC
Door Module, Left - Mopar (68374091AF)
Passenger side mirror- 68361476AC
Door Module, Right - Mopar (68374090AF)
Front camera- 68417514AA
Radiator Grille: 68443251AA (Big Horn Black Grill)
Tailgate Handle: 6RN80GXHAA (Basic Black Handle)
RAM backing plate for front camera- 68459116AA (Fits Big Horn Grill)
Chrome Trim Pieces for Grill - 6NB37SZ0AB
Front camera bracket- 68386821AA
Front camera bezel- 68364534AA
Front camera screws (2)- 68386822AA
All Those parts come out to about $2,500, however i saved a good chunk of money getting the mirrors used off ebay.
Fakra Universal EXTENSION Cable (Choose Length Desired)
Fakra Direct Female to Female Universal Cable (Choose Desired Length)
You also need a custom Harness to give the CVPM power and access to the CANBus, there's a few members on here that can help with that. Hopefully they'll see this and chime in.
Also since you have to get the fancy Tow mirrors to get the side cameras, and you'll have Power convex mirrors with them, i suggest spending the extra $15 on the power convex button so you can take advantage of them.
Mirror Switch - Mopar (52112478AA)
Again though, to work, this button will require a very small inexpensive custom harness that can be made by other forum members.
Hope this helps.
Edit: Here's the list of values that must be changed in AlfaOBD
CustSetMenu 3 Rear Cargo Guidance Lights Enable/Disable CSM Present: Yes
That will put the setting in the radio to enable/disable them.
Doors: Mirror Rear Guidance Lights: Yes
They are turned on and off using the cargo lamp switch.
Doors: power convex mirror: Yes
Surround View:
VehConfig 1 rear view camera- no
VehConfig 1 CHMSL camera- no
VehConfig 7 full central vision processing present- yes
VehConfig 8 digital CHMSL camera present/ yes (if using the cargo camera)
ECUConfig 3 rear camera present- no
Radio and connectivity surround view camera on/off soft key present- yes
CustSetMenu 1 rear view camera grid lines CSM present- no
CustSetMenu 1 rear camera CSM present- not present
CustSetMenu 2 rear view camera delay CSM present- no
CustSetMenu 2 surround view camera gridlines CSM present- yes
CustSetMenu 2 surround view camera delay CSM present- yes
CustProgFeatures static gridlines enabled- no
CustProgFeatures dynamic gridlines enabled- no
Lin CustProgFeatures rear view camera static gridlines enabled- disabled
Lin CustProgFeatures rear view camera dynamic gridlines enabled- disabled
Cabin Net CVPM central vision processing present- yes
