PCT
I snagged a LXmx will work for android/ windows.
Do you have SGW bypass cable installed?I think I might have figured it out. It will only connect under body computer.
I was trying to connect under tire control as I am only trying to adjust tire pressures ![]()
Turn your truck’s lights on. Turn the flashers on. Walk around the rig.Did anyone get the trailer light check to work on the 2020 trucks? There was a bunch of posts and then it went quiet so I assume not
Tried enabling it in the BCM and it didn't work.Did anyone get the trailer light check to work on the 2020 trucks? There was a bunch of posts and then it went quiet so I assume not
Try swapping the two leads that hook into the bypass and see if that works.I'm trying to change tire pressure thresholds. I have the MX+ and Kaodtech bypass installed. But OBDLink, AlfaOBD and JScan all give me errors when connected to the bypass. Alfa says CAN ERROR Connect Failed, JSCAN says the Module - Connection Test False when running the ELM327 identification. Am I missing something or is this just a bad bypass cable? They all talk to the truck fine without the bypass.
Swap them around. The black connector should go in the white base terminal and the white connector should go in the black.Just finished flipping through all the pics in this thread. Think I have the wrong harness. But the plugs work. There are no white/green black/green labels like I saw in a previous post.
I ordered the 2019 - Current HD:
The yellow/blue is the key, as @HWTG said, swap the connectors.Just finished flipping through all the pics in this thread. Think I have the wrong harness. But the plugs work. There are no white/green black/green labels like I saw in a previous post.
