colport142
ahh..so dont pull it....8-speed trans has an emergency neutral release behind the panel.
I didn’t pay attention to “classic” 1500. Yeah, it uses a different connector all together for the CAN IHS. You would need a different bypass, or cut that connector off and put the correct one on. Right now, as long as the other one is plugged into the green block with black base, you should be good for most changes. You just won’t have access to any modules on the IHS bus.Here is my connector...two different sized plugs..
what would be in that bus I wonder..my lights changes worked...I could find plug and make three plug adapter...wonder if they are generic?I didn’t pay attention to “classic” 1500. Yeah, it uses a different connector all together for the CAN IHS. You would need a different bypass, or cut that connector off and put the correct one on. Right now, as long as the other one is plugged into the green block with black base, you should be good for most changes. You just won’t have access to any modules on the IHS bus.
All the body modules are on that bus- doors, HVAC, blind spot, center stack, etc. The BCM is the master node on both buses, so most settings should work with only the canbus C bypassed, until you come across one that doesn’t.what would be in that bus I wonder..my lights changes worked...I could find plug and make three plug adapter...wonder if they are generic?
OK, so getting a little braver and want to see about changing a few things with the AlphaOBD. Here is a list of things I look at last night in the program. Can someone explain what they do and are they viable changes? I have the program, bypass cable and OBDLink LX. I've changed my tire size and TPMS settings so I know the system works on my truck.
Thanks for any and all input. Still learning here.
2021 75th AE Power Wagon
ECUConfig 4-Actual Gear Display
CBC Features-Front Fog Lamp Dropout Enabled
Got the gear present and fog lights programmed and working.
Tried the performance page, but couldn't find it anywhere in the uconnect or the EVIC
Do I need a pin if using the aplhaobd and security bypass?I'm using it on my 2020 2500 and it works perfectly. I purchased the bypass from kaodtech
Sorry for not specifying, I am going to be using my Galaxy note 10.I just opened the log and did save as to my computer.
How can I back up my stock BCM settings with alphaobd, I don't use google drive. Still waiting on my SMB from Kaodtech, and hope i got the right one 2019+ ram 2500 for my 2021 Ram 2500 Big Horn
