sstoner911
There is a link to one in the AlphaOBD thread under the modifications forum or the ALPHAOBD website.
KAOdTECH is the industry standardJust got my 2022 Cummins in , I have Android fire tablet with Alfa obd to my understanding I need the security bypass cable is this correct ? And if so can someone point me to a good one ?
So I went through all the threads on alfaobd and was curious if anyone had updated a list for 2022 2500. Looks like the previous confirmed changes list was from 2020, just curious if there’s been any new tricks found? Currently waiting on bypass cable to start playing with mine.
Do you have the bypass cable in correctly? I had mine swapped once and coukdnt get in, even though I swear I had it in correctly.I am not having any luck even with the bypass cable to get into make any changes. I’m searching trying to find things I can change as in fog lights on with high beams and seatbelt alarm
I was wondering about this when I ordered everything, my cable and Mx+ should be here this week I will give it a try and report back.I am not having any luck even with the bypass cable to get into make any changes. I’m searching trying to find things I can change as in fog lights on with high beams and seatbelt alarm
How far did you venture into it ? Just curious if there’s anything that would not work from the old list on here.Bypass cable works fine. I used it on my 22 and my buddies 20.
I don't see why any of it wouldn't work, so long as you do supporting mods. I tried tilt in reverse mirrors, but you need the memory seat and mirror module for it to work. It's not something I need bad enough to add modules for, but if I added the modules, it should work.
I added remote start, got a dedicated button for my front camera, and turned on the option for my mirror blinkers to be running lights.
Try something out, see if it works. If it doesn't work immediately, have no fear. Sometimes it takes a few key cycles to work. Of course, it might just not work at all because you don't have the right physical setup.
I'll fix that real quick. 2022 2500 Tradesman. Snow chief and Tow Tech.You don't have any info in your sig, do you have a 2500 or 3500?
You don’t need memory seats or the memory seat module for tilt in reverse to work, you just need memory mirrors.I don't see why any of it wouldn't work, so long as you do supporting mods. I tried tilt in reverse mirrors, but you need the memory seat and mirror module for it to work. It's not something I need bad enough to add modules for, but if I added the modules, it should work.
What exactly are you experiencing with AlfaOBD, or, what won’t it let you do- not connecting to the body computer at all, not responding when making a change in car configuration change, etc? What message pops up when whatever you are doing doesn’t work?It works on my scan tool but will not let me with alfaobd
From what I read, the memory seat module is also the memory mirror module. My mirrors have every option but memory, and just turning the options on did nothing for me.You don’t need memory seats or the memory seat module for tilt in reverse to work, you just need memory mirrors.
Nope, memory seat module not needed, just memory mirrors. I currently have 2021 memory mirrors with cameras fully loaded on my 2017, no memory seat module, and tilt in reverse works. Same for everyone else that has swapped in memory mirrors without MSM.From what I read, the memory seat module is also the memory mirror module. My mirrors have every option but memory, and just turning the options on did nothing for me.
Windows version? What OBD interface? Sounds more like an issue between AlfaOBD and the interface.It will fail to connect. Once I thought I had it connected tried to do something with seatbelt and it won’t let me I will have to try and take a pic of the message. If I use same tablet I can use the diagnostic part no problem
…and, the seatbelt chime doesn’t work with AlfaOBD, if that’s what you are trying to do. That procedure will fail.It will fail to connect. Once I thought I had it connected tried to do something with seatbelt and it won’t let me I will have to try and take a pic of the message. If I use same tablet I can use the diagnostic part no problem
Also all I want to do is turn in high beams with fog lights and get rid of seat belt but so far it’s a no go for seatbelt and I can’t find the fog lights been long time since I did that on my 2015 ram
