Wasy
Hello, I have a new Big horn 2500 and a new 2021 Forest River TT with a furion camera adapter mounted on the rear. I have an after market backup camera and monitor that worked perfect on a 2015 ram Laramie towing a 2016 TT. The monitor works when plugged into the cig lighter and so does the camera. The problem arises when I plug the camera into the furion adapter where it belongs. The camera won’t turn on. Measuring voltage at the adapter is 11.6 where voltage at cig adapter is about 12.6. When both items are out of the truck and plugged into 110v to 12v adapter they bluetooth and work fine.
I read on another site posted by a fellow who had a denali and had the same problem as me that there was not 12+ volts coming thru the 7pin to the marker lights due somewhat to the led lights not needing 12 volts and the furion camera adapter. I talked to the cam manufacturer and were told the cam would not work without 12 volts. Their advice, hard wire it.
sorry this is so long I have an idea what to do I don’t want to mess things up while still under warranty
