Jim's 3500 Ram
Is it me or does it bother anyone else with the hoop flapping around in heavy wind conditions? I came from a 2018 2500 with steal to a 2019 3500 aluminium. Just seems odd to me.
Yes it is bad. My hood is the same way and drives me nuts. A few threads on here with possible fixes and adjustments. Worth the read- May or may not work for you.Is it me or does it bother anyone else with the hoop flapping around in heavy wind conditions? I came from a 2018 2500 with steal to a 2019 3500 aluminium. Just seems odd to me.
Yep drives me nut also. I saw them about adjusting the stops. The light weight tailgate awesome lol.Yes it is bad. My hood is the same way and drives me nuts. A few threads on here with possible fixes and adjustments. Worth the read- May or may not work for you.
My 18 didn't do what the 19 doing. Not going to mess with the stops.Your 2018 had an aluminum hood also. The 2018 hood will float in the wind too.
Lots have said they adjust the bump stops and it fixes it. Same as the 4th Gen. Some do it some don't
Gotcha! I live in a pass area where the wind is constant. Just can't help to wonder if it's just going fold up over the windshield someday That's fine. The HeavyDuty has had an aluminum hood since 2010. Adjusting the bump stops has helped.
Sometimes a good heavy shut helps too.
Really didn't know that. Thanks for the info.Also, I think there was a issue with the 1500s not having the proper adhesion of the cross members of the hood and that there may have been a TSB issued for this.
Funny. They must have figured out how to make a magnet stick to aluminum then if my ‘17 has an aluminum hood.That's fine. The HeavyDuty has had an aluminum hood since 2010. Adjusting the bump stops has helped.
Yup. 2019 is the first year for aluminum hoods on the HDs. Only the 1500s have been using aluminum in the previous years.Funny. They must have figured out how to make a magnet stick to aluminum then if my ‘17 has an aluminum hood.
