mountainears
Technically, I am creating the option. On the other side of my 12 pins, there is no wire going out. Can you send me a picture or any piece number or any other information regarding the 12 pins behind the bumper. For example, any number on the plastic connector or any mopar number on the wires that are connecting. Thanks!I hate to be that guy, but are you _sure_ the 12 pin plug is connected solidly? I had the same issue when I tested my camera setup and that plug really needs to be seated well.
Thanks for all your links and timeForgot one more thread that'd be useful to you - you'll need the trailer security gateway module installed as well.
12 pin connector and Trailer Surround View Camera
If I have the 12 pin connector on my truck and have the towing technology group b. Can I purchase trailer surround camera system, part# 82216421ab-001 and it will work for my truck? I also have the 5th wheel prep group so does that mean the 12pin connector only works on the bed and not from the...hdrams.com
I bet his trailer is like mine. It's either one or the other due to the height. I have to either keep it tilted up to see behind me or tilt it down to see directly behind. The digital adjustment isn't enough between the two clicks at the physical camera.Doesn't the DRVM tow mode camera tilt down in Reverse?
(that's a rhetorical question...)
IOW, have you adjusted the tilt when you set it up?
I read that it would do that but there is no mechanical tilt, it changes the field of vision to show down as far as possible, if you have made pan adjustments in running mode. However, if you physically tilt it way down to the ground it is no longer useful as a general rear view mirror past about one tailgater. I did some trial and error drives before finding my preferred tilt. Mine is also at the standard trailer cam position about 8ft off the ground which hurts the downward view. Lastly, I'd much rather have a backup cam view in the uconnect screen than the smaller drvm screen (actually both at once would be sick).Doesn't the DRVM tow mode camera tilt down in Reverse?
Honestly you’d be better off selling your trailer surround kit and just buying the single aux trailer camera. Plugs into the same port but is a lot simpler and cheaper.I read that it would do that but there is no mechanical tilt, it changes the field of vision to show down as far as possible, if you have made pan adjustments in running mode. However, if you physically tilt it way down to the ground it is no longer useful as a general rear view mirror past about one tailgater. I did some trial and error drives before finding my preferred tilt. Mine is also at the standard trailer cam position about 8ft off the ground which hurts the downward view. Lastly, I'd much rather have a backup cam view in the uconnect screen than the smaller drvm screen (actually both at once would be sick).
I'm excited to try the single rear cam, but if someone knows ahead of time it's futile without all 4 installed then I'll leave it mint in box.
Honestly? That was the direction I thought I'd go about a week ago but there is very scattered and conflicting info on the exact mopar part number and I can't find examples of the image quality when selecting it as AUX2. At least I've seen images of the 360 cams and it looks great, and it is compatible with my particular 2024 packages/options because it came with the truck. Still unsure if it can work with only the rear populated.Honestly you’d be better off selling your trailer surround kit and just buying the single aux trailer camera. Plugs into the same port but is a lot simpler and cheaper.
I assume your Ram is 2024 or 2025?I am about to start the camera install on my Jayco Travel trailer. I thought when I bought the truck it only came with a rear camera but it came with the 360 camera set up. Do I have to mount all the cameras? My camper has a rounded front cap so that camera would be difficult to mount. Also can you use the system while driving? Would be nice to see what is behind you and limit blind spots.
