2022 Ram Tow/Trailer Camera Options
Let me check the part number on the NIB kit I have at home tonight.
Sounds good.
I know the older kit basically gets rid of the repeater and has a different camera part number.
I am guessing I'd need the newer camera and run a new cable that doesn't use the repeater.
I have a couple of questions I didn't see directly addressed in this thread that I could use your help with. I have a 2022 Ram that did not come with the 360 surround cameras but I would like to add the Trailer Aux 1 and Aux 2 camera kit. I have the trailer kit with the single camera and bought the 12 pin connector assembly for the back of the truck. My first question is do I need the CVPM for the 360 kit to make it work and does anyone know the harness part numbers and wiring diagram?
Does anybody know if 82216510AA is the correct part number for the truck side prep for the Trailer Aux camera kit?
I hope I’m not repeating what’s already been posted… (I’ve read thru so many threads seeking the answer, but haven’t found what I need to know…. Hope someone can help me)…
…I have a 2024 Ram 2500 Limited 6.7 CTD and it has the 12 pin…but I DON”T want the 360 view… I want a Tow-camera for my DRVM.
My selling dealer shipped the 86886112AA it to me…and I installed it…. ONLY to find that the Coax “Dock” on the bumper is NOT connected to anything! :confused:
The selling dealer is at a loss…and so is my local dealer (who probably feels they shouldn’t have to deal with this. Short-story: Wrecked my Ram in KY and had to buy another to get the travel-trailer back home. Salesman didn’t know what he didn’t know and told me they’d ship the camera to me to fit that coax-dock for the tow-camera.)
I THINK what we need is some sort of “jumper harness” which connects my Coax-Dock to the DRVM harness…??
(I’ve tried to PM Jimmy07 but haven’t rec’d response yet.)
Hope someone knows the answer to this. Thank you.
I have a 2022 Ram 3500 that I added the DRVM and Tow Mode cam. On the 2022 this is a stand alone system where the CHMSL camera and Trailer camera both wire to the Digital rearview mirror (2 Fakra connectors). I believe on the 2023-24 both cameras route through a Video Processing Module under the driver's seat. The cameras are a different format and can't plug directly into the DRVM. The harness I have that runs from the rear bumper to the back of the cab is 68527158AA. Then a small jumper connects and runs through a body plug at the driver's rear corner of the cab. From there you would need the harness and VPM to connect to the DRVM.
I'm going to be installing the 360 cameras on the trailer I tow with my 2022 and I plan to leave out the front camera in the next few days. I'll let you know how it works.
Did you do the install or have someone else install? I recently bought the 360 kit and sent it to the RV dealer to install. They couldn't install because the cables weren't long enough. So they said. I contacted the seller and he sent cable extensions. I picked up the trailer before the extensions arrived. So the trailer/camera kit are in Idaho and I'm in California. I know the cameras work but this whole cables not long enough and install issue is frustrating me. I looked for some videos covering install but couldn't find any. Can you tell me how everything went for you?
The ANSWER to the problem I had posted earlier regarding no harness attached to the truck-side of the “dock” for the DVRM mirror/trailer camera…is SOLVED. Despite a Ram dealer “tech” looking for it and not finding it…another participant here (Damonb) convinced me to Drop the spare tire and search for myself….and …VOILA!
HIDDEN above and behind another twisted harness I found an unoccupied FARKA connector. I used spray contact cleaner to insure cleanliness and plugged it into the back of the bumper “dock”…. and the trailer camera immediately WORKS!
THANK YOU Damon!
