2022 RAM 3500 Dually Wheel Packages
nyrescue
I just received my 2022 3500 Dually night edition with auto level. I do use it to pull a fifth wheel, what would you recommend for bigger tires, etc? I need to watch overall lift and rubbing, we use it camping a lot and want something aesthetically pleasing, but also functional.
The biggest tire that you can put on stock wheels without needing spacers is a 255/80r17
Mine looked like that one time. For about 70 miles.
The wheels are 20” fuel Blitz D675 and I went with 37-12.50-20 Cooper STT pros. I have the Carli 2.5 leveling kit and since I have factory air had to go with 1” rear blocks for axle and airbags.
This picture is makes it look like they stick out a lot, but they don’t, I’m not home now but will be Saturday and if needed I can get better pictures.
Nice! What setup is that?
Can you get a back shot of that? How far past the rear fenders do the tires stick? Is there a way to fit 35's and have the rear tires stick a maximum of 1" past the rear fenders?
Nice!! Yea I was wondering how things are different for us guys with the automatic leveling.
I went with a set of Fuel Triton 20x8.25 the rears are -211 offset I believe. I'm really happy with the stance.. the tires are 35x12.5x20 mud champs and stock front suspension no rubbing. hen I replace the tires I will go with a 275x65x20 AT tire that is slightly shorter and narrower just for personal preference.
Wow looks really good. How much gap is between the duallys? Do you have spacers?
About 3/4" between tires if I remember correct.. no spacers the wheels are made to run that tire size.. but I will be going a little narrower, they have a little more offset than i would like. I'm hoping a narrower tire will help.
Also, I swapped out to Toyo AT3's, as I could never get those Ridge Grapplers to balance properly. The Toyo's are the same size
Firebird,
Truck looks Great!
What are you running for inner wheels?
Are you using any sort of spacer?
I like those wheels - may go with the black on my granite 3500, was looking at these and the Vision 181 Haulers
Ford part / compatible inner I guess then? (can't seem to find one listed for a ram at 6.5w)
Would you have a measurement or estimate of space between the duals?
I'll grab you a measurement on that spacing
