I just received my 2022 3500 Dually night edition with auto level. I do use it to pull a fifth wheel, what would you recommend for bigger tires, etc? I need to watch overall lift and rubbing, we use it camping a lot and want something aesthetically pleasing, but also functional.
Can you get a back shot of that? How far past the rear fenders do the tires stick? Is there a way to fit 35's and have the rear tires stick a maximum of 1" past the rear fenders?
Nice! What setup is that?
Nice looking truck. Any more pictures of the back?Not the best pic, but I went with Ion Alloy's and 255/80/17 Ridge Grapplers. I tow regularly, and didn't want to go too big
Wow looks really good. How much gap is between the duallys? Do you have spacers?I went with a set of Fuel Triton 20x8.25 the rears are -211 offset I believe. I'm really happy with the stance.. the tires are 35x12.5x20 mud champs and stock front suspension no rubbing. hen I replace the tires I will go with a 275x65x20 AT tire that is slightly shorter and narrower just for personal preference.
I will get you some tomorrow morningNice looking truck. Any more pictures of the back?
About 3/4" between tires if I remember correct.. no spacers the wheels are made to run that tire size.. but I will be going a little narrower, they have a little more offset than i would like. I'm hoping a narrower tire will help.Wow looks really good. How much gap is between the duallys? Do you have spacers?
Thank you!Firebird,
Truck looks Great!
What are you running for inner wheels?
Are you using any sort of spacer?
I'll grab you a measurement on that spacingI like those wheels - may go with the black on my granite 3500, was looking at these and the Vision 181 Haulers
Ford part / compatible inner I guess then? (can't seem to find one listed for a ram at 6.5w)
Would you have a measurement or estimate of space between the duals?
