huck1974
2022. Sub beats like a drum for 1000 miles now for no reason at all. Told them to disable the noise canceling tomorrow until they can figure something out. Has been annoying first 1000 miles.
I’m think I’m having the same issue.
After a certain speed the low bass drone kicks in. I’ve been sick and I thought I was hearing things in my clogged up ears and head.
Feel better today and still noticed it.
I’m not hearing things. It’s definitely there. It’s for sure a real thing.
I’ve seen at least one other person comment on this somewhere.
Can it be turned off?
I don't run the show here but throwing this in Interior is a travesty.
It sounds like a rattling booming noise from the suspension or exhaust and is hard to figure out. I still don't know if this is exactly the problem.
More attention is needed to this issue than hiding it here. I would never look here if I had this problem. Dumb.
Dealer will turn it off tomorrow. No fix yet.I’m think I’m having the same issue.
Not the type of person to give a lot of ****sNew posts boil to the top.
If you have a problem with moderation, PM someone or report the thread/post. FWIW, Calling out mod actions in the forums is against the rules you agreed to when you joined, particularly if you use the words you've chosen. Let this be your free warning.
Please elaborate on 'Dealer will turn it off tomorrow'. Turn what off - and how will the dealer do that? I'm curious in case this becomes a problem for me. Thanks!Dealer will turn it off tomorrow. No fix yet.
If it's the ANC being deactivated you could just pull the fuse for it under the hood (ANC) and see if it makes a difference for you.Let me know if you immediately hear a difference. Not wanting to make another dealer trip so soon. Went in last week for the Uconnect to be told no solutions right now.
Good thing this truck looks cool as hell because that’s about the only thing working for it right now.
You can do it with AlphaOBD.from the owners manual.
Your vehicle is equipped with an Active Noise Cancellation system that cannot be turned off. This system is designed to address exhaust and engine noise. The system relies on four microphones embedded in the headliner, which monitor exhaust and engine noise, and assists an onboard frequency generator, which creates counteracting sound waves in the audio system’s speakers. This helps keep the vehicle quiet at idle and during drive. The system is deactivated when the windows are rolled down.
Owners Manuals are for suckers
