2019-2024 2500 / 3500 Jumpseat to Center Console Swap
Just sharing some information i've found after swapping my 2024 Ram 2500 crew cab from the factory jumpseat to a full feature center console with all features working.
You'll need the following parts from the dealer, to mount the console and close the holes left on the dash from the jumpseat and trim being removed.
For the 2023-2024 trucks, absolutely DO NOT BUY the infotainment jumper harness, it's junk and doesn't provide full power, front and rear usb to work correctly. Instead order the following harness from the dealer:
The above harness allows the console swap to be a full 100% plug and play into even a base model tradesman.
DO NOT follow the infotainment install and unplug the USB hub and USB input at the back of the hub facing outward on the console. You absolutely must plug in the factory USB cable from the lower dash, into the single USB female port on the front right hand USB connector, by the console harness plug. The rectangular connector from the OEM USB hub on the lower dashboard is left disconnected, you can tuck it up into your dashboard.
Hopefully this information helps, as i've now supplied over 26, 2024 center consoles for people to install in their trucks.
I have a 2021 2500. I’m currently doing the console swap. My truck originally had 120 volt in the dash. The center console has one 120v in the front and one 120 in the rear. I’m in need of an extension harness to plug these in . Any knowledge of a harness or part number?
Thats how mine was, The Big H connector (circled in red) under the seat will power both of those. I pulled the H plug up through the carpet and was able to run it up front to plug into the new console. The old 120v from the dash is not used, I wrapped in tape and zip tied it behind the dash. On my new console I have 120v power in the cubby and in the plug in the back seat area11.jpg
I have a ‘24 with a bench seat. I’m trying to get the center console with the wireless charger. Would all of this help me achieve this? And would it be as easy to plug and play? Or are would there be more steps to get the wireless charger to work? Thanks
