2019-2024 2500 / 3500 Jumpseat to Center Console Swap
can any one help me I have a 2023 larime with a jump seat I bought a business center console and the extension wire for under the seat but I can’t get the wires in the dash to plug in so I’m wondering if there is an extension harness are if there is anything I can do?
I have a 2025 3500 Tradesmen. Anyone want to swap my seat for your center console?
I need some help. I have a '23 Tradesman that I'm attempting to swap the jump seat out for a full console from a '22 Bighorn.
The Tradesman has -
- USB/ 1 aux port on the dash panel
- 110v outlet on the dash panel
- usb port in the arm rest
- no rear ports for the back seat.
Bighorn console has -
- usb/aux ports at the dash
- usb in the arm rest
- front 110v outlet in the console
- rear usb ports
- rear 110v outlet
I got the "H" connector from under the driver seat rerouted and moved to the front with room length to spare. I removed the cubby, the lower panel on the drivers side and the radio stack. Cut all the cable ties and freed up the usb cable and the square connector harness that went to the hub and rerouted and got some extra length. Plugged in the "H" connector, the usb out of the dash to the port beside it and left the square plug unplugged for testing because it has to be extended because my console has the offset right usb ports.
Here is where things go very wrong... when I hit the start button to see if it had power, the console (female) usb port instantly went up in smoke?? I killed power and unplugged it but the female port is toast. The dash side cable is looking rough but works fine. My question is what would cause it?
Just sharing some information i've found after swapping my 2024 Ram 2500 crew cab from the factory jumpseat to a full feature center console with all features working.
You'll need the following parts from the dealer, to mount the console and close the holes left on the dash from the jumpseat and trim being removed.
For the 2023-2024 trucks, absolutely DO NOT BUY the infotainment jumper harness, it's junk and doesn't provide full power, front and rear usb to work correctly. Instead order the following harness from the dealer:
The above harness allows the console swap to be a full 100% plug and play into even a base model tradesman.
DO NOT follow the infotainment install and unplug the USB hub and USB input at the back of the hub facing outward on the console. You absolutely must plug in the factory USB cable from the lower dash, into the single USB female port on the front right hand USB connector, by the console harness plug. The rectangular connector from the OEM USB hub on the lower dashboard is left disconnected, you can tuck it up into your dashboard.
Hopefully this information helps, as i've now supplied over 26, 2024 center consoles for people to install in their trucks.
Would you be able to sell all items needed and the console? My husband has a 2024 2500 big horn and is wanting to get rid of his jumpseat for the full console.
110v to the usb?
Would be interested in learning what that part number is…
Has anyone done this with a floor t-case shifter? I imagine some cutting of the console would be required. Or maybe you could do a shifter extension with a sideways bent to get the shifter further left and out of the “pocket”
Ive been happy with my bench seat, but it does feel like a bit of a waste of space compared to the full center consoles, even though I do have the armrest storage, under seat storage, and cupholders on the floor console (4th gen floor console installed).
Any chance this got answered? Looking to do an install in a 2021 tradesman.
I have a 2019 Ram 3500 Laramie black leather seats. I have the jump seat and I want to swap it for a console. My jump seat has the real 110v outlet, rear seat heater buttons, and rear usb ports. Would be willing to sell or trade and would include all dash pieces (drawer and trim) mounting brackets and hardware. If anyone would like to trade me please message! Really want a console.
Where does that harness plug into? Under the drivers seat?
I'm doing a console swap and I watched the infotainment way of doing it. Can you explain what you meant with the usb hub and input? By the way the part numbers came in clutch!! Thanks!
Did you ever figure this out?
Ive got the leather laramie jumper seat in seek of the full console no logos on the 24’s its just black leather. Truck has 5k miles on it seats brand new if anyone would like to trade.
Hi Rammer249 is the jump seat still available
not to undermine anyone, but if he does not, I have one. 189 miles, never sat on. brand new.
I assume this all should work for my 22 2500 Laramie? Eventually would like to convert to the 12” screen vs this 8.4” screen .
Bringing this one back from the dead. Did this swap today, was super simple. Found a full length console from a 2500 at a yard about a hour from me so I drove and picked it up Then bought a new kit on ebay that came with all the brackets, hardware and trim pieces. So far I am just over $800 into it. This thread and youtube helped greatly. Everything went flawless except for some reason the media hub up front under the radio doesn't work? Some videos showed to plug the existing media hub and usb directly into the plugs on the new console, others said to just plug in the USB and the big H connector from under the seat. I pulled the H plug from under the driver seat up through the carpet and it was long enough to plug up front, I then plugged in the single grey USB into the grey usb on the console. Both 12v outlets work, usb inside the armrest works and both usb's for the back seat work. Luckily my truck has wireless carplay so I can live without the front media hub. When it warms up I may look into it more
Bringing this one back from the dead. Did this swap today, was super simple. Found a full length console from a 2500 at a yard about a hour from me so I drove and picked it up Then bought a new kit on ebay that came with all the brackets, hardware and trim pieces. So far I am just over $800 into it. This thread and youtube helped greatly. Everything went flawless except for some reason the media hub up front under the radio doesn't work? Some videos showed to plug the existing media hub and usb directly into the plugs on the new console, others said to just plug in the USB and the big H connector from under the seat. I pulled the H plug from under the driver seat up through the carpet and it was long enough to plug up front, I then plugged in the single grey USB into the grey usb on the console. Both 11v outlets work, usb inside the armrest works and both usb's for the back seat work. Luckily my truck has wireless carplay so I can live without the front media hub. When it warms up I may look into it more
I did the same last week and only the front usbs and the one in the arm rest work, rear usbs and outlets don't works. do you have pics of the plugs you used? I plugged in the T-harness and the one grey plug next to it.
I only plugged in the Big harness (1) that looks like a H and the one grey USB (2) next to it. The big plug with the orange X was not plugged into anything on mine. I'm temped to plug it into the media hub on the new console and see if it works
Do you still have the old center console trim pieces . Would you sell them
