cj8rockcrawler
So if I've had the grid heater nut failure, does that mean the Diesel gods will protect me from the lifter failure?
If you have luck like I do, it means you better just plan to do the Hamilton swap tomorrow.So if I've had the grid heater nut failure, does that mean the Diesel gods will protect me from the lifter failure?
Sounds like my luck.If you have luck like I do, it means you better just plan to do the Hamilton swap tomorrow.
Thats a good attitude that most of us should share. But what are these "appropriate mods" you mentioned?Two years ago, I bought my first RAM/Cummins - a 2021 with 23K. I did a bunch of research before my purchase then made appropriate mods for peace of mind. When i joined the forum, I began reading about all the other possible issues that were different from my earlier research. Then started asking a bunch of question out of curiosity and anxiety. Several members told me to enjoy the truck and drive without 'worrying' about failures as most people who join forums are there because of problems. I took their advice and am happy with my RAM, it is an amazing and beautiful truck.
If I have any problems, I will deal with them, if any.
Banks cold air intake, monster ram, boost tubes, 5" exhaust, BD Diesel 68RFE pressure boost, trans pan and thermal bypass. I did these mods prior to joining here.Thats a good attitude that most of us should share. But what are these "appropriate mods" you mentioned?
Yes I saw a blip about the additive year or so ago, if I recall correctly the additive is from germany/EU, I also don't think the info was for the US dealersHas anyone heard of an OEM 6.7 engine oil additive, recommended by Ram?
At my dealer today, scheduling fuel filter service x 2; my rep and I talked about the Lifter TSB Ram issued. He looked it up and suggested Ram prescribed an engine oil additive, but he couldn't find what additive, then suggested it was not issued in North America.
Has anybody heard this or is the Rep too far over his skis?
Thanks
Yes,https://rotella.shell.com/en_us/promos-loyalty-rewards/warranty.html anyone see the Shell Rotella warranty on engines
I’m sure Shell is going to say known mfg defect. Pound sand.https://rotella.shell.com/en_us/promos-loyalty-rewards/warranty.html anyone see the Shell Rotella warranty on engines
Couldn’t pay me to run rotella, warranty or no warranty.https://rotella.shell.com/en_us/promos-loyalty-rewards/warranty.html anyone see the Shell Rotella warranty on engines
With my engine seeing 4% Fuel Dilution Rotella T-6 does not hold up well even at 5K for I no longer use itCouldn’t pay me to run rotella, warranty or no warranty.
Its name brand swamp water.With my engine seeing 4% Fuel Dilution Rotella T-6 does not hold up well even at 5K for I no longer use it
Yes. This is a “thing”, but not applicable to the North American market. Not sure why specifically.At my dealer today, scheduling fuel filter service x 2; my rep and I talked about the Lifter TSB Ram issued. He looked it up and suggested Ram prescribed an engine oil additive, but he couldn't find what additive, then suggested it was not issued in North America.
Thanks
Maybe it was an experiment to see if it would help without admitting there was a problem with their oil recommendations or a defect. I don’t know how litigation antsy they are in SA.Yes. This is a “thing”, but not applicable to the North American market. Not sure why specifically.
Note that the “NA” (North American) box is not checked under the “market applicability” section, and to my knowledge, no bulletin for the NA market exists with this additive recommendation.
