If you want a little more confidence in your wheels holding on to your tires when airing down, but you don't want all the hassles of a bead lock wheel, try the Method bead grip wheels. I'm running the 17" Method 704 HD, which was built specifically for Ram trucks. These wheels "grip" the bead of the tire - but are
not bead lock wheels. They don't lock the bead onto the wheel, but they do hold the bead better than regular wheels. Just ask the guys at Discount Tire (or any other shop that works with these wheels) - it is hard for them to get the tire off the wheel.
For tires, I run 35-inch Mickey Thompson Baja Boss AT, and I air them down to ~20 psi driving moderate trails (OnX OffRoad rated 4-5). Occasionally I run a trail rated 6 (but that just makes me want 37s). So far, no concerns about losing a bead. I think I could take the tires down to 15 psi and still be fine.
