Darkone
As the title states I’m needing some help
With wiring. To be more specific grounding. I’m in the process of hard mounting an arb twin under my truck, which has snowballed into making a custom wiring harness, to include a rear 12v/usb power port mounted in the bed. I’ve decided to use a grounding block to make any future wiring needs easier.
My problem and question is mounting. I’m using a Blue sea 2104 stud block. It may be a bit over kill but I’d rather have more than I need and I’m going to be adding a front and rear Anderson ports that will attach to this. I plan on attaching this to the block and the frame then all my negatives will attach here rather than the battery. The plastic base is removable which would allow easier mounting can I hard mount this directly to the frame or will I cause myself problems.
I’m sure there are those out there that have better understanding of wiring that could help me out on this. I apologize for the long windedness to get to the question but I hope a little context will help with understanding what I’m trying to do
