Wireless Charging Option?
techman
Apr 5, 2022
Is wireless charging standard on all 12" UConnect systems? I put my phone in the charging "area" and nothing happens. My phone has wireless charging and no case, but as far as I can tell it doesn't detect a wireless charging pad. It's a tall phone so I have to lay it sidewise. Is that an issue?
CharlieL
Oct 28, 2021
Albuquerque
Are you sure you have the wireless charging pad? You can double check by getting an Equipment Listing using your VIN. Use this link. I have the charging pad, and have found that if the phone is not placed "just right" the wireless charging won't work.
techman
Apr 5, 2022
It is not on my equipment list. I had thought it was standard on all 22's with the 12" Uconnect 5.
I don't even remember seeing it as on option and I chose equipment level "C" on my order.
jerryw1000
Jan 15, 2020
Don't know about the '22s but on my '20 Laramie with the 12" screen on the build sheet it specifies "Ramcharger Wireless Charging Pad" and on the Sales Code sheet it says "RFXP Ramcharger Wireless Charging Pad". I cannot remember if this was a separate order item or part of a package.
BSN81
Jun 10, 2022
I had it as an option on my 2020 Laramie. It was listed on the window sticker. I had heard it was not available as an option for late 2021 and all of 2022 due to a lack of parts. But it's now available for 2023. I will say though the thing was very finicky and barely worked. I usually just used the usb-c.
CharlieL
Oct 28, 2021
Albuquerque
Sounds like you don’t have it, then. As said above, due to shortages certain options weren’t available depending upon build date. When I was shopping, I learned that I could not get power folding mirrors if I ordered a custom build. Those are an absolute necessity for me due to width of my garage door. Hopefully the lack of wireless charging is overcome by the rest of your truck..
Sixtime43
Apr 3, 2022
I believe there are kits out there with the oem parts, etc... I was considering doing this myself at one point. Might have to revisit this... plugging in your phone is annoying. lol, first world problems right?
Aug 12, 2022
It was supposed to come with my 2022 Laramie (2HH) but they just left it out.
It’s obvious if you have the shelf for ram charger or not. USB are justified to the right, not centered.
techman
Apr 5, 2022
Confirmed...do not have it and that's ok. Thanks for everyone's help
Icky
Sep 6, 2021
I have it on my 22 and it sucks. It's not a fast charger, have to take it out of my case ( my desktop one will charge through the case) and it's in a weird location
CharlieL
Oct 28, 2021
Albuquerque
My opinion is different. The charger is sufficiently "fast" enough for while in my truck & I don't need to remove the case. Sure, my desktop charger is faster & plugged into 120 volts. To be expected. While driving, especially on longer trips, I am not one bit concerned about the rate of charge. When I stop after a few hours of driving, it's usually at 100%. The charge goes up, even with the phone in use through Carplay. The location is fine with me; I don't need to be looking at the phone while driving & can use all of the features through voice - including responding to text messages. While I initially had some difficulty finding "just the right" location in the charger, that's not a problem any more. As long as the phone is pretty much centered, or left of center, on the charging spot, no problem. Right of center, that's the "no charge" zone.
jebruns
Feb 28, 2022
I just got my 22 Ltd Longhorn and it has the wireless charging, so it was certainly available on 22 builds. I got to test it on my 400 mile drive home and it worked great on Samsung S22 Ultra with a case.
DeepH20Driller
Mar 15, 2021
I installed one a Course Motorsports wireless charger, to have phone closer by. It works well. Has a motorized clamping system. Hard wired it behind dash.
