It's actually not as easy as it first seems. However, here goes
On the front, the tire at the bottom is approx. 1/2 inch inside the outside edge of the top of the flare.. The 'face' of the wheel is about 3in inside the tire.
So, about 3 inches.
But the face of the wheel isn't flat, so depends on where you measure it.
The fender flare isn't completely vertical, flat, so measured from the center top, widest bit. Measured from at the height of the rim, it's way different.
Don't have level ground, so eyed to make equal distance to top/bottom of the wheel. (Assuming 0 camber)
The back is different
Only measured 1 side, assuming the axle is centered with the body. (Depends on what tolerance you are talking about)
Also, I don't have standard wheels or tires or suspension height.
It's a 2020 if that makes any difference.
Might help if you explained what the measurement is for?
