Hit the scales again Friday. Had the whole family in the cab, 5 people, the dogs and some gear in the bed for a weekend away (that failed, but that’s another story)
5760/4340. Running 57/40 for pressure and it handles great.
Sadly I’d be over GVWR on a 2500. I wasn’t even heavy enough to get into Alt trailer height.
Something has to change on vehicle classifications, this is ridiculous. Luckily GVWR doesn’t mean crap in many states, including Idaho.
For standard sizes yes, but as you can see by the chart I posted not all flotation sizes follow that.
P is also a funny thing, some are 35 and some are 44. XL are 44, but not all load and inflation tables account for that. The toyo table for P tires doesn’t even go to 44 psi, despite them offering tires rated for it.
P are also only rated for 90% of their weight rating on SUV’s and pickups, but nobody ever talks about that.
You should probably look again… there is only one line on the Toyo chart for you size tire and it covers D,E,F rated tires. This chart has been relatively unchanged for 10+ years, so I’m not sure what Toyo chart you looked at.
I have seen a lot of OEM load and inflation tables, and none of them work they way you described for LT tires of the same size with different load ratings.
Lots of floatation tires are 65 psi max for E range tires. The same chart also shows this.
