What kind of cool things can you do with AlfaOBD ?
OuterUB
Oct 12, 2021
Sorry if this is already out there but I couldn't find a list per se.
kevin588127
Jan 13, 2022
So far, I've done the fogs on with the high beams, enabled the gear indicator to show what gear you are in and set my TPMS sensors to a lower threshold. Eventually I will be using it to turn on the cargo cam option but I will be using it for a grill mounted, forward facing camera. I was also going to use it to change tire size when the time comes but that may be handled with the pulsar that I just installed.
OuterUB
Oct 12, 2021
I like the high beams and gear indicator thing..... very cool.
Crusty old shellback
Apr 10, 2021
All the above, and adjusted tire size. Also turned off the Cali/Miss. nanny that wont let me have the LED aux light in the mirrors on when moving in reverse. :rolleyes: :mad:
Still looking into raising the speed nanny as well. I hate it when you go to pass someone and the speed nanny kicks in at 96 MPH. :rolleyes:
CFE
Jan 3, 2022
Is there a list/cheat sheet with all of the things we can do w/ alphaobd?
Apr 10, 2021
jsalbre
Oct 29, 2019
ID
That will require an ECM tune unfortunately. It’s set from the factory based on the originally equipped tires’ speed rating.
CFE
Jan 3, 2022
Apr 10, 2021
I see the setting in Alfa. Haven't tried changing it yet. Not sure if anyone else has tried. It's a bunch of numbers, I think tire rpms, not actual speed.
OuterUB
Oct 12, 2021
buzzuti
Dec 19, 2021
TEXAS
FWIW, no surprise, there is an FB group that looks to be very active, Ram AlphaODB Users;
If you're into that FB thingy...
  • Like
Reactions: CFE
CFE
Jan 3, 2022
only reason i even have fb anymore is for the marketplace and bourbon/ram groups
jsalbre
Oct 29, 2019
ID
Several people on cumminsforum and on some of the other forums have tried changing that and ended up with it setting itself to 0, requiring a new PCM to fix it.
