What HD and Hitching equipment are we using.
What are HD are we using with what hitching equipment
  • Total voters
    86
Burn'n Oil
It's a metaphor!
Oct 3, 2019
Great White North
30 ft Rockwood (rolling dog house) coupled with a Reese (round bar) Strait-Line WDH. Almost 6K kms the past few months. Towed this TT with a Hemi powered 1500 for over 40K kms. We're spending 40 percent less on fuel with the Cummins powered 3500.
brucie
Sep 18, 2019
I guess I will revive this thread with my gear. In September I purchased a 2019 Laramie with the 6.4 in delmonico red. The RAM site says I have a 3200# payload capacity. I tow an approximately 6000 pound Outback Terrain 210TRS. Only about 24 feet long but about 900# plus on the pin. We use an Equalizer WD hitch with sway control. My former vehicle a 16 Tundra was crushed with all the pin weight, hitch weight, gear inside and tonneau cover along with passenger weight. I replaced the 2 inch shank with a 2.5 inch shank when I got the Ram and good thing. The 2 inch shank had a very noticeable bow in it.. The shank had a 1000# capacity and the new one has a 1400# capacity. I've only towed twice with it, the first time a test run of about 60 miles and the second time about a 250 mile round trip. I was pleased to see about 10mpg, which was what I was getting with the Tundra. The stability of towing with the Ram is a 1000% improvement and the Tundra wasn't that bad. We towed that trailer cross country 2x and probably put 20K miles on the trailer or more. It did get nerve racking getting sucked into and then spit out of the wake of every tractor trailer that went by. From what I could tell with the Ram, that will be greatly improved. The body drop after adding the trailer and over 1000 pounds of cargo is under 2 inches with WD. Very impressed with that part of my ownership.
Klinger
Dec 4, 2019
41.5’ 5th wheel. Life’s trailer approx 17,000#
the pic with the people in it is NOT my RV but exact model and identical to mine
Possum
Dec 2, 2019
Bumper pull with adjustable Weigh Safe hitch. Pulling ski boat, pontoon boat, 7000 lb car hauler trailer, and a 10,000 lb 7x12 dump trailer. Not hitting max weight too often, but too much for a 1500 most of the time. Loving my 2500 with air suspension. Towing something several times a week.
What size drop did you go with?
I went with a 10". It'll be here Saturday so I haven't tried it. I read that the Weigh Safe doesn't give you a full advertised drop so I went 10" just in case.
foneguy
Nov 8, 2019
2019 tradesman long bed with cummins
3.73 gears tows loke a dream !
40 ft sportsman 344bh 4 slides gross of only 12Klbs
Possum
Dec 2, 2019
Towed about 10k the other day
RLange
Jan 15, 2020
Going to be pulling a Grand Design Reflection 29RS 5th wheel using a Demco autoslide 13K hitch with a Dodge factory prep. Adding airlift 5000 with on board air control wireless one gen2
Silver Dawg
Dec 20, 2019
46 ft. DRV JX 450 Toy Hauler with Andersen hitch system. I cant get the truck to change to the heavy EOH brake setting. Starting a related thred -
