Weird sound when initially moving forward
Roxhound
Oct 8, 2023
Greetings,
I have a 23 2500 6.7 stock. Have 4k miles on it, and sometimes when i back the truck up, when i shift to drive there is a noise. It seems like a transmission thing, because as it goes forward it makes the noise, but it goes away. Only lasts for like a second or so.
Am wondering if this has been heard/seen before and if i need to get it to the dealer before it becomes a problem.
Thanks again.
flan
Aug 16, 2019
Is it a buzzing noise?
Roxhound
Oct 8, 2023
Greetings,
I got word from another group, this is a "feature".
Seth Katz said his 3500 4wd does the same thing the dealer said it was normal it’s just flexing
Pasta4lnch
Oct 12, 2023
Lawn Guyland, NY
Just got my 3500 hemi and I think mine does it too. Freaked me out driving it off the lot but stopped almost immediately. Happens almost every time...
jsalbre
Oct 29, 2019
ID
None of you have said what exactly the noise is, but if it’s a buzz/hum/vibration noise then it’s the ABS system check.
Roxhound
Oct 8, 2023
Oh, i am sorry, been really busy to answer. It is a whineing sound. Not a buzzing/hum/vibration. kinda like when a wheel bearing squeels, but is coming from below your ass in the truck.
Riddick
Aug 12, 2021
Yorktown, VA
Is the truck rolling backwards when you shift into drive? If so, try coming to a complete stop before changing gears.
Hambone11
Feb 14, 2023
My 2022 2500 does the same thing. After reversing and shifting the transmission into drive, I get a quick squealing sound just like you describe. I come to a complete stop before shifting as I’m sure you do too. I don’t remember it ever happening when going from drive into reverse. Only when backing, then shifting into drive. I am wondering what it is as well. I have the 6.7 (Not the HO). Have you figured out what the noise is yet?
Ramsomair
Mar 9, 2023
Same thing here on my last 4 Rams. No ill effect was ever noticed.
Chrisminx
Nov 12, 2020
It's been happening since the 4th gens came out in 2010. I've had 6 (4 tradesmen, 1 limited and 1 laramie). The 4 with the 68 made the noise, but the 2 with the G56 did not. Dealer says it's normal.
LegendaryLawman
Legendary Pessimist
Oct 20, 2022
My fathers 22 does the same thing. Sounds like a squealing pig. Only when backing up, then quickly into drive does the pig make its noise. Otherwise she’s quiet
