WDH set up
SL1
May 21, 2021
Im about 1/2 inch lower in the front of my travel trailer than the back with the wdh set up and it appears to be pulling good and seem stable. Truck measure good in the front(within 1/4) and about 1.5 low in the rear. Would adding another washer to the pitch of the hitch fix this or should I let enough alone? How close to level does the trailer pull best?
Thanks in advance for your input.
Frank
Sep 29, 2020
Missouri
The chain link is what matters. Adding a washer effectively lengthens the chains and takes tension off the bars. Follow the process, which will likely require adding a washer or two, until the front is at 0" to +1/4". Being -1/2" you've pushed too much forward.
04KAT600
Aug 7, 2020
Personally if the truck and trailer are riding good I'd leave things alone. Your measurements are almost identical to my set up and it rides great so I haven't felt the need to mess with it.
  • Like
Reactions: SL1
