Has anyone had issues wirh water leaking from the cab lights? Waiting on new seals from dealer, still no answer if they are replacing the headliner.
That is aggravating. Mine is leaking right in front of the sunglass holder on the headliner. Doesn't leak wirh every rain though.Mine has been to the dealer twice and they cannot find the leak. It drips from the grab handle on the drivers side. I’ve shown them video and they said they have to replicate the leak before they can do anything. They have a spray bar thing they park it under and it hasn’t leaked when they do that. I’ll be bringing it back in again until they do something.
It won’t leak under the spray bar or when it’s raining/carwash.
It’s frost build up on the inside of the roof. When you drive the truck or as the sun warms the roof it melts and drips out the handle and or sunglasses holder areas.
I have attached pictures of the inner roof from the cab mounted brake light. It looks like an ice cave when the conditions are right.
Should be an easy fix then.Mine leaks when it rains. I don’t think they’re spray bar simulates a hard rain cause they’ve done it twice and not got it to leak.
I'm going through this with my 2008 right now. If leaking through the grab handles, I think your front drains for the sunroof are plugged. There are little nipples below the front door hinges. You should try to open up the nipple with a bent rod of some sort. When you open up the drain nipple, water should/may drain out - might fix the problem. be careful using compressed air to open the drains - could separate the hoses under the headliner......Be Brave!Mine has been to the dealer twice and they cannot find the leak. It drips from the grab handle on the drivers side. I’ve shown them video and they said they have to replicate the leak before they can do anything. They have a spray bar thing they park it under and it hasn’t leaked when they do that. I’ll be bringing it back in again until they do something.
If you have a sunroof I would bet that’s where the leak is. My 21 2500 had been to the dealer 4 times and then I took it to a dealer 100 miles down the road and they fix it the first time.Mine has been to the dealer twice and they cannot find the leak. It drips from the grab handle on the drivers side. I’ve shown them video and they said they have to replicate the leak before they can do anything. They have a spray bar thing they park it under and it hasn’t leaked when they do that. I’ll be bringing it back in again until they do something.
When is it getting looked at again?So the last time I took it in they said they fixed the leak, they say it was the back window. Next rain it was leaking again and they said it’s the rear window and showed me, well the spot they showed me is about 4” lower than where the water was dripping inside. My leak comes from the speaker behind the drivers seat and also from the phone speaker right above the driver seat and the grab handle on drivers side. They brought it back in and say they found it and they are now putting in a new sunroof. Hopefully that’s it.
I have another appointment the 22nd of April.
They installed new glass in the sunroof. Haven’t had rain since so not sure if that fixed it. I’ll report back after the next good rain we get.
Please...Stop with the logic!!Can't you just spray water on with a hose to check it?
