Thorvald
- Joined
- Nov 7, 2020
Discovered this new device thanks to this forum. Their website is www.voltsafe.com and they are starting to be sold in a few store chains in Canada and the USA.
My order arrived today, shipped out quick from the manufacturer even though they used Canada Post (regular mail, usually not a good idea for speed but good for costs). The App was recently updated so now it supports scheduling and appears to keep the schedule even after powering off (based on quick testing).
One item that needs work is the cover, it's pretty loose and looks like it might flap around easily. Thankfully the magnet is on the vehicle mounting side so I'll just silicone or superglue a small ferrous nut inside the cover over the magnet and that should hold the cover closed at all times. Something I'll suggest to the manufacturer that they add. The power cord is about 10 feet long and contrary to what some of the info I heard from videos, it did not include an adapter for normal plugs. So you'll need to bring the cord with your if you need to plugin at your destination. I'll post up a YouTube unboxing later.
For those that do not know about this device, its a magnetically attached power cord for your block heater that is app enabled. If you (or your better half) forget to unplug the vehicle when leaving, no issue, it just pops off without dragging a cord down the highway. Also very easy to just "click" connect it at night without needing to get down under your license plate/bumper to find that blasted block heater cord.
Very impressed by the unit so far (they were on Dragons Den years ago), now I just need the weather to get actually cold again to use it!
Inside the box was the unit and three zipties plus a foam pad. The foam pad just sticks to the back of the unit so it doesn't scratch up your grille (also compresses nicely with the zipties). It fits perfectly on the 3500 lower grille and can be easily removed in the summertime since it's just two zipties.
