@Brav - not sure if you did this, but there are a few additional inputs you need to do in Alfaobd when you change the tire size. I have included the procedure I used and have zero faults or inability to use back-up cameras, etc. See the attached PDF file.
Basically, right after you enter the tire size circumference and press "start" (cycle to off, wait a minute, and then back to run) - you need to go back into Alfaobd and select:
Note - you're going to get a bunch of flashing lights and alarms - the following will clear them up.
- Your truck model
- ABS
- ABS Ate/Continental
- Click the "hood open" icon at the bottom
- Select "ABS Initialization" from the drop down (read the instructions)
- Press Start
- Back to the drop down and select "Static ECU Initialization"
- Press Start
- Click on the "check engine" icon at the bottom
- Select "Clear Faults"
- Cycle the key to off and then back to run
- Click back on the "hood open" icon
- Select "Clearing Rolls Information" from the drop down (should be at the bottom of the list)
- Cycle key again
- Although it doesn't say it, I would click on the "check engine" icon one more time and clear faults
- Turn key off and disconnect everything (OBDII connector, etc.)
- Start your truck up and take it for a spin
When I entered the circumference for my new tire size, I used the actual measured size from the manufacturer. For example - I have 37" tires, but they actually measure 36.54". I used the tire size calculator in the Alfaobd thread on the other Ram Forum and came up with the correct number to enter...and it worked!
Hope this
