So Alfaobd was able to get this menu enabled for me. Now all six of my buttons are working. I can still only change 1-4 in the EVIC. The menu still shows the switches in the radio settings but I can't make any changes. Thanks for the info.Contact Alfaobd, they can enable that option for you.
I have not tried this yet. I can change the settings for switches 5 & 6 within Alfaobd and once I set them I don't plan making very many changes. ThanksTry option 2-5 to see.
Yeah, if you asked for upfitter, they might have thought you wanted the VSIM.
I highly recommend that you order from your dealer as this switch panel comes in many many versions , panel only vs kit (6.4L or 6.7L?, parking sensors?, etc...)
Multi Switch - Mopar (68381308AE) <-- ONE EXAMPLE ONLY
6.4L, with aux swtc, with air susp with prk snsr, without front sensors.
Kit just refered to a complete upfitter setup, which includes the extra upfitter wiring kit, not just the switch panel.I was just wondering what you mean by kit ?
Will this work for a 2020 Tradesman? Am I correct in your statement that it will work but will not show as doing so?it won't show for your truck. if you want the one like I have, here's the link.
Thank you sir!!!it will fit and plug in as factory. it won't "work" until you do the rest of the job.
If you got it from the factory you would have it all installed and only need to connect to the grey conectors by the pdcHello,
I have a 2019 ram 3500 that I added the aux switch bank in the dash at the factory. Mine has the air bags etc... and I was able to get the correct switch bank. Everything works accept what I want.... the aux switch’s... my truck has the factory aux pdc box. It is wired to one side (hot) in the fuse but that’s it. I would need the fuses, wires, relays for the pdc and from what everyone is saying the wires to the switches. Is anyone selling this kit around here? I just bought a new bumper with lights and really now need to finish these aux switch’s. Any help would be appreciated.
For clarification, the only factory items that came on the truck are the auxiliary pdc (Not wired for aux switch’s) I just had the factory install the new switch bank in the dash with the aux switch’s... the truck did not have it factory. to Finish this I need the followingIf you got it from the factory you would have it all installed and only need to connect to the grey conectors by the pdc
seems i may be using factory loosely here.... I am old... factory meaning had the dealer install the switch bank in the dash... not literally sent back to the factory to be installed.For clarification, the only factory items that came on the truck are the auxiliary pdc (Not wired for aux switch’s) I just had the factory install the new switch bank in the dash with the aux switch’s... the truck did not have it factory. to Finish this I need the following
wire up the aux pdc (looking for a kit from someone for all these connectors and wires)
relays (these are on order)
fuses (need to order)
grey plugs that sit next to pdc under hood (anyone know the part number for these two connectors?)
what is not clear to me is how much or how far I need to wire to the switch’s for the control wires... is it from the y125 plug only? Is it from the switch bank?
How many wires do I need to add through the fire wall?
can the factory flash the truck to accept the new switch bank? Or is the only way using after market alfaobd reader thingy?
I used to install car stereos so I have some knowledge of how to wire stuff up just don’t know how much I need, as everyone talks about having to wire to the switch’s but they don’t say how many wires they ran and how far they had to go
Ty for the picture. The aux pdc is a ton of wires. You did this yourself? And how many wires did you have to run through the fire wall and where did they connect too? The switch plug? The y125 plug? Both lol ?there's a whole mess of wiring that has to be completed. the switch bank is the easy part.
