Epsilon Plus
- Joined
- Sep 11, 2020
This is going to sound like a silly post to most, but it might help someone. I've noticed a few clunk/hard shift out of P/R/N/D posts on different outlets and thought I would share my experience.
I think most of us are programed to throw a vehicle lever around and not feel a clunk, as most vehicles are not 8,000 pound HDs in previous history. I, for one, have always used a parking brake (some people say emergency brake) no matter if I'm on flat ground or a hill...etc.
With the 2500, it seemed like this wasn't enough, and I'd still get a decent clunk or heavy shift feel off of the parking pawl in the trans. I started going to neutral for every parking/reverse maneuver and it hasn't clunked since, incline or not. This may seem simple, but how many people really pull up, go to neutral, let it set, then go to reverse, stop, go back to neutral, off brake to let it unload the suspension into neutral, and then to park + parking brake? Even I don't do that EVERY time and when I don't? Clunk.
Give it a shot. Give the suspension a chance to unload off the direction you were going and let the weight "rest" before throwing that shifter around and it will be smooth as butter going through the selections.
Also, while I'm here, pro tip: Once your in 6th gear cruising, hit the "-" symbol on the Gear Limit switch on the wheel once, and it will show what gear you are in on the DIC (the 7" one at least). It won't drop a gear down until you tap it again and limit a gear down, one press will just activate the display. I say do it once you are in 6th, because if you do it in say 3rd, it will hold you to 3 gears and you'll have to "+" your way up the range. Again, something silly for most but I've also seen a few posts asking about current gear display on different platforms.
Cheers.
Cheers.
