TSBs
Admin
Site admin
Nov 16, 2018
Age
41
Vancouver, B.C
Here is a sticky thread that everyone can post TSB's in. So the thread doesn't get too cluttered please try to refrain from discussions in this thread and post TSB's only.
Please Include:
  • TSB#
  • TSB description
  • Models and years affected if known
  • A link to TSB or PDF or upload an attachment
Thanks
Admin
Site admin
Nov 16, 2018
Age
41
Vancouver, B.C
thestuarts
Jun 10, 2019
TSB 23-010-20 REV. A a.k.a. (RRT) 20-020
Description:
SUBJECT: Sunroof Water Leak
OVERVIEW: This bulletin involves testing the sunroof for leaks and replacing the power sunroof glass, if necessary
Models:
2019 (DS) RAM 1500 Pick
2019 (DJ) RAM 2500 Pick
2019 (D2) RAM 3500 Pick
2019 (DX) RAM Truck (Mexico)
Link to TSB: https://static.nhtsa.gov/odi/tsbs/2020/MC-10175564-9999.pdf
Notes: My dealership performed the syringe test in the TSB and determined my vehicle needs the repair.
thestuarts
Jun 10, 2019
TSB 08-012-20
mod: (Superseding TSB 08-149-21) Updates DASM to 56029827AH
Description:
The customer may describe one or more of the following:
  • Brakes may intermittently apply unexpectedly together with Instrument Panel Cluster (IPC) warnings.
  • IPC warnings for the Forward Collision Warning (FCW) informing the driver to apply the brakes.
Models:
2019 (D2) RAM 3500 Pickup
2019 (DD) RAM 3500 Cab Chassis
2019 (DF) RAM 3500 <10K Cab Chassis
2019 (DJ) RAM 2500 Pickup
2019 (DP) RAM 4500/5500 Cab Chassis
Link to TSB.
Alternate link to TSB.
Notes
This updates the DASM module to version 56029827AG.
I have driven my truck 23,000 miles, and only twice has the truck unexpectedly applied the brakes and displayed the FCW. It happened when there was absolutely nothing in front of the truck for miles, so I thought it was a bug or a bird that tripped the sensor, but apparently this is a sporadic software glitch.
thestuarts
Jun 10, 2019
TSB 08-016-21
Models:
2019 (JL) Jeep Wrangler
2019 (WD) Dodge Durango
2019 (WK) Jeep Grand Cherokee
2019 (LD) Dodge Charger
2019 (LA) Dodge Challenger
2019 (RU) Chrysler Pacifica
2019 (DT) RAM 1500 Pickup
2019 (KL) Jeep Cherokee
This bulletin applies to vehicles equipped with one of the following radios:
• Uconnect 3 with 5” Display (Sales Codes **UMA, UKA, ULA,** UAA, UCA, UJA, UDA or UGA).
• Uconnect 4 with 8.4” Display (Sales Codes **UMM, ULM,** UAM, UCM, UDM, UGM or UJM).
• Uconnect 4 with 7” Display (Sales Codes **UKG,** UAG, UCG, UDG, UJG, ULG, UGG or UMG).
Description:
Radio and Back-up Camera Enhancements
SYMPTOM/CONDITION:
Customers may experience one or more of the following:
• **Radio display screen flickers.
• Clock loses 6 seconds per day (JL with 5 inch screen).**
• Green horizontal lines on back up display, in reverse (If this is the customer concern use camera LOP 18-60-02-W2, on DT and JL vehicles only).
• Ghost Touch, features, modes and App’s changing without drivers input.
• Speaker pop noise when using Bluetooth device.
• When vehicle is first start the radio will reset and the time display shows 12:00.
• Audio distortion and volume fluctuation.
• Blank rear camera image in reverse (If this is the customer concern use camera LOP 18-60-02-W2, on DT and JL vehicles only).
• Audio distortion (KL vehicles).
• Audio cutting in and out during memory recall.
• Ring tone too loud.
• AM/FM volume fluctuates.
• While in CarPlayT or Android Auto GoogleT maps showing wrong location.
• Phone disconnected after first call.
• Black screen or White screen with vertical lines.
• Personal Identification Number (PIN) clears and volume locked while KeySense is used.
• Audio static while in SXM/SAT modes.
• Echo heard during Bluetooth phone calls.
• The radio is locked up.
• The radio remains on after ignition has been turned off.
• The radio resets.
• The radio screen turns black.
• Intermittently requires an anti-theft code to be entered.
TSB document.
Notes: This may be delivered over-the-air eventually, but for now you can request your dealer to install the update if you are experiencing any of the symptoms.
Software update also includes software enhancement.
• SXM sound and behavior improvements.
NUMBER: 08-094-20
GROUP: 08 - Electrical
DATE: October 10, 2020
SUBJECT: Flash: Drivetrain Control Module (DTCM) Update
4x4 Transfer Case flash update for 2016-2020 for trucks built on or before June 14 2020
https://static.nhtsa.gov/odi/tsbs/2020/MC-10183078-9999.pdf
The customer may experience a Malfunction Indicator Lamp (MIL) illumination. Upon further investigation the technician may find the following Diagnostic Trouble Code (DTC) has been set:: NOTE: If the customer has any concerns with the transfer case or if the tech performs any repairs on the transfer case, the software must be updated. • C140E - Transfer Case Motor Blocked. NOTE: If DTC C140E is present, follow normal diagnostic procedures before updating the DTCM. In addition the customer may describe the following: • The “Service 4WD” message/fault is displayed in the Instrument Panel Cluster (IPC). • Transfer case shift fork tabs broken during range shift. • Noisy (clunking/ratcheting) transfer case range shifts. • Failure to complete transfer case range shifts. The following software enhancement is available: • This update will help reduce premature transfer case failure
NUMBER: 18-009-21
GROUP: 18 - Vehicle Performance
DATE: February 2, 2021
Components: POWER TRAIN
NHTSA ID Number: 10188798
Summary
Flash: Powertrain Control Module (PCM) Updates
2019 - 2020 (DJ) RAM 2500 Pickup
This bulletin involves reprogramming the Engine Control Module/Powertrain Control Module (ECM/PCM) with the latest available software.
Customers may experience a Malfunction Indicator Lamp (MIL) illumination. Upon further investigation the technician may find the following Diagnostic Trouble Code (DTC) has been set: P0299-00 - Turbocharger Underboost.
https://static.nhtsa.gov/odi/tsbs/2021/MC-10188798-9999.pdf
Turbocharger Underboost Additional Diagnostics:
https://static.nhtsa.gov/odi/tsbs/2021/MC-10188769-9999.pdf
TSB 08-052-21
NUMBER: 08-052-21 GROUP: 08 - Electrical DATE: March 26, 2021:
SUBJECT: Flash: Radio Frequency Hub Module (RF-HUB) Updates
OVERVIEW: This bulletin involves reprogramming the RF-HUB with the latest software available.
MODELS:
2020 - 2021 (DJ) RAM 2500 Pickup 2020 - 2021 (D2) RAM 3500 Pickup 2020 - 2021 (DD) RAM 3500 Cab Chassis 2020 - 2021 (DF) RAM 3500 <10K Cab Chassis 2020 - 2021 (DP) RAM 4500/5500 Cab Chassis 2020 - 2021 (DX) RAM Truck (Mexico)
NOTE: This bulletin applies to vehicles within the following markets/countries: North America, APAC, EMEA and LATAM. NOTE: This bulletin applies to vehicles built on or before January 29, 2021 (MDH 0129XX) equipped with Remote Proximity Keyless Entry (Sales Code GXD).
SYMPTOM/CONDITION: The customer may experience the following: • The key fob won’t unlock the doors while the vehicle is running and after a remote start.
https://static.nhtsa.gov/odi/tsbs/2021/MC-10190730-9999.pdf
Vehicle Performance TSB 18-012-21 REV A. (RTT 21-027)​
NUMBER: 18-012-21 REV. A
DATE: March 5, 2021
This bulletin supersedes Technical Service Bulletin (TSB) 18-012-21, date of issue February
05, 2021, which should be removed from your files. All revisions are highlighted with
**asterisks** and includes converting to an RRT, repair steps and LOP.
**This Technical Service Bulletin (TSB) has also been released as a Rapid Response
Transmittal (RRT) 21-027, date of issue March 05, 2021. All applicable Sold and Un-Sold RRT
VINs have been loaded. To verify this RRT service action is applicable to the vehicle, use
VIP or perform a VIN search in DealerCONNECT/Service Library. All repairs are reimbursable
within the provisions of warranty. This RRT will expire 18 months after the date of issue.**
SUBJECT:
OVERVIEW:
MODELS:
2020 (D2) RAM 3500 Pickup
NOTE: This bulletin applies to vehicles within the following markets/countries: North America.
NOTE: This bulletin applies to vehicles equipped with a 6.7L I6 Cummins Turbo Diesel
Engine (Sales Code ETL) or a 6.7L I6 Cummins HO Turbo Diesel Engine (Sales Code ETM).
SYMPTOM/CONDITION:
investigation the technician may find that one or more of the following Diagnostic Trouble Codes
(DTCs) have been set:
• P20E8-00 - Reductant Pressure Too Low.
• P0301-00 - Cylinder 1 Misfire (Sym Cam Pump Only).
• P0302-00 - Cylinder 2 Misfire (Sym Cam Pump Only).
• P0303-00 - Cylinder 3 Misfire (Sym Cam Pump Only).
• P0304-00 - Cylinder 4 Misfire (Sym Cam Pump Only).
• P0305-00 - Cylinder 5 Misfire (Sym Cam Pump Only).
• P0306-00 - Cylinder 6 Misfire (Sym Cam Pump Only).
• P1C54-00 - SCR NOx Catalyst Missing.
• P242F-00 - Diesel Particulate Filter Restriction - Ash Accumulation (68RFE Only).
• P2463-00 - Diesel Particulate Filter Restriction - Soot Accumulation Bank 1 (68RFE Only).
• P1451-00 - Diesel Particulate Filter System Performance (68RFE Only).
• P0299-00 - Turbocharger Underboost.
• P2706-00 - MS Solenoid Circuit (68RFE Only).
• P1D73-00 - AGS Performance.
• P2463-00 - Diesel Particulate Filter Restriction - Soot Accumulation Bank 1.
• P1451-00 - Diesel Particulate Filter System Performance.
• P242F-00 - Diesel Particulate Filter Restriction - Ash Accumulation.
• P24A5-00 - EGR Cooler Bypass Bank 1 Control Stuck (Sales Code ETM).
• P20EE-00 - NOx Catalyst Efficiency Below Threshold (Sales Code ETM).
• P0420-00 - Catalyst System Efficiency Below Threshold Bank 1 (Sales Code ETM).
• P2002-00 - Diesel Particulate Filter Efficiency Below Threshold (Sales Code ETM).
• P0191-00 - Fuel Rail Pressure Sensor Circuit Performance (Sales Code ETM).
• P0461-00 - Fuel Level Sensor 1 Performance (Sales Code ETM).
• P0401-00 - EGR System Performance (Sales Code ETM).
• P208B-00 - Reductant Pump 1 Control Performance (Sales Code ETM).
The customer may also notice one or more of the following:
• Harsh downshift clunk during exhaust brake deceleration.
• Diesel Exhaust Fluid (DEF) gauge erratic when DEF level is low.
• Stall when putting in reverse in cold ambient temps.
• Engine stumble during engine warm up.
• Unstable idle when AC compressor cycles.
• Engine surge felt while driving (Sales Code ETM).
• Idle fluctuation.
The following improvements are also included in this update:
• Oil change monitor improvement for severe duty operation.
• wiTECH “Fuel Injector Cutoff Test” fix.
• wiTECH Mass Air Flow (MAF) Sensor data display additional fix.
• Enabling wiTECH Particulate Matter (PM) Sensor Regeneration Test in PCM “Misc Functions”.
• Engine Warm-up Protection Improvement to help promote better oil delivery to engine
bearings during cold starts.
• Hydrocarbon Desorption (HCD) Mode operational improvement. HCD mode resumes after key
cycle.
• Engine stumble improvement, during engine warm up (Sales Code ETM).
• Smoke improvement during highway driving and lower altitudes (sea level) (Sales Code ETM).
  • Vehicle performance 18-012-21 REV. A MC-10190691-9999.pdf
DEF OVEFILL OR ICE
NUMBER: 18-034-21
DATE: April 2, 2021
This bulletin is supplied as technical information only and is not an authorization for repair. No part of this publication may be reproduced, stored in a retrieval system, or
transmitted, in any form or by any means, electronic, mechanical, photocopying, or otherwise, without written permission of FCA US LLC.
SUBJECT:
P203E and P203F Additional Diagnostic Information
OVERVIEW:
This bulletin provides additional information regarding diagnosing Diesel Exhaust Fluid (DEF) issue
in extreme cold weather. Diagnostic Trouble Codes (DTCs) P203E - Reductant Level Sensor 1
Circuit Intermittent and/or P203F - Reductant Level Too Low set.
MODELS:
2019 - 2021 (DJ) RAM 2500 Pickup
2019 - 2021 (D2) RAM 3500 Pickup
2019 - 2021 (DD) RAM 3500 Cab Chassis
2019 - 2021 (DP) RAM 4500/5500 Cab Chassis
America, LATAM, EMEA and APAC.
Engine (Sales Code ETL or ETN) or 6.7L I6 Cummins HO Turbo Diesel Engine (Sales Code ETM).
DISCUSSION:
Several reports have been received of vehicles in the field setting DTCs P203E and/or P203F.
Many of these vehicles were located in areas of extreme cold, or in areas where the temperatures
can go from extreme cold to warm in short periods of time. An analysis of returned parts from
several of these vehicles has shown a high rate of No Trouble Found (NTF). Further analysis of
information returned from the field, has narrowed down the cause into 3 possible scenarios.
• Scenario #1 - DEF Tank Overfilled.
• Scenario #2 - Residual Ice in the DEF Tank or Covering the Level Sensor.
• Scenario #3 - DEF Crystallization Covering the Level Sensor.
NOTE: If you encounter a vehicle with the above condition, please review each scenario
below, and repair accordingly prior to replacing any parts.
DEF Level Sensor Operation:
The DEF level sensor is new starting in the 2019 Model Year. The new design level sensor uses an
Ultrasonic Frequency (UF) signal to detect the proper fluid level. Previous model years use a radio
frequency type sensor which operates differently, and can be less accurate.
In order for the UF level sensor to operate properly, it is crucial that there is sufficient air space
between the top level of the fluid, and the top of the DEF tank. DEF tanks are specially designed to
have an air space above the fluid, which is crucial for the level sensor to function. Without that air
space, the UF signal cannot be returned to the sensor properly leading to a “No Echo” condition.
<CONT>
  • DEF 18-034-21 MC-10194039-9999.pdf
Components: SEAT BELTS, ELECTRICAL SYSTEM
NHTSA ID Number: 10194066
Manufacturer Communication Number: 08-052-21 REV. A
Summary
The customer may experience the following: The key fob won't unlock the doors while the vehicle is running and after a remote start.
This bulletin supersedes Technical Service Bulletin (TSB) 08-052-21, date of issue March 26,
**asterisks** and include updated sales codes.
SUBJECT:
OVERVIEW:
MODELS:
equipped with **Remote Start System (Sales Code XMB) and Selectable Tire Fill Alert
(Sales Code LA5) or Tire Fill Alert (Sales Code LAW)**.
SYMPTOM/CONDITION:
DIAGNOSIS:
Using a Scan Tool (wiTECH) with the appropriate Diagnostic Procedures available in
DealerCONNECT/Service Library, verify all related systems are functioning as designed. If
Diagnostic Trouble Codes (DTCs) or symptom conditions, other than the ones listed above are
present, record the issues on the repair order and repair as necessary before proceeding further
with this bulletin.
If the customer describes the symptom/condition listed above, perform the Repair Procedure.
TSB 18-012-20 (rev unknown)​
Labor Op code 18-20-09-94​
Previously STAR case #S2019000002 Hands On Steering Wheel Message In EVIC
Previously posted as TSB-012-20 for 2019 vehicles https://hdrams.com/forum/index.php?threads/tsbs.3028/post-67116
Case Number:
S2019000002
Release Date:
04/17/2020
Symptom/Vehicle Issue:
Discussion: On vehicles equipped with Lane Departure Warning (LDW), a driver may experience a message on the cluster display instructing them to "Place hands on steering wheel" when their hands are already on the steering wheel and LDW is on.
This can occur and doesn't indicate an issue with the vehicle or any ECU.
Hands on steering wheel detection sensing is done by monitoring driver torque on steering wheel over a period of time. Driving on straight and flat roads does not require much steering torque input from the driver and can trigger a warning to "Place hands on the steering wheel". During this warning if a small steering wheel movements is detected the message will no longer display.
  • 9-13-21 truck in for various repairs. issue noted.
  • 9-16-2021: Dealer called to say there's a flash available. I will update the TSB post when I know more.
  • 9-17-2021: Received vehicle back with labor Op code 18-20-09-94 - Flash DASM with latest code (found in TSB 18-012-20)
I wasn't able to find the specific TSB, not do I have the DASM firmware code level, but it appears this TSB was upated or rolled up into a large TSB for park sense, FCW braking, lane sense issues, etc.
TSB 09-009-21
SUBJECT:
Accessory Drive Belt Chirp Noise
OVERVIEW:
This bulletin involves inspecting the accessory drive belt pulleys for signs of damage, and if no
issues found, replacing the crankshaft pulley and drive belt.
MODELS:
2019 - 2020 (D2) RAM 3500 Pickup
2019 - 2020 (DD) RAM 3500 Cab Chassis
2019 - 2020 (DP) RAM 4500/5500 Cab Chassis
chirp chipmunk squeal squeak belt
Thorvald
Nov 7, 2020
Does anyone have a copy of TSB 18-067-23?
It may actually be on this forum somewhere, but the blasted search engine built into this thing won’t let you search for numbers.
SYSTEM​
DATE PUBLISHED MAY 24, 2023
NHTSA TSB #10239973
TSB Document 18-067-23
  • Sorry, the NHTSA has not posted this TSB document yet.
You can still get the detailed info from Ram for this TSB. Call your local Ram dealer's service department & ask for a copy of TSB# 1806723.
Summary. This bulletin involves reprogramming the Engine Control Module/Powertrain Control Module (ECM/PCM) with the latest available software.
thestuarts
Jun 10, 2019
I am posting this for @Thorvald
  • TSB# 18-067-23
  • TSB description
    • See below
  • Models and years affected:
    • 2020 (DJ) RAM 2500 Pickup
    • 2020 (D2) RAM 3500 Pickup
    • This bulletin applies to vehicles equipped with a 6.7L I6 Cummins
    • Turbo Diesel Engine (Sales Code ETL) or a 6.7L I6 Cummins HO
    • Turbo Diesel Engine (Sales Code ETM).
    • North America
Customers may experience a Malfunction Indicator Lamp (MIL) illumination. Upon further investigation the technician may find that one or more of the following Diagnostic Trouble Codes (DTC)s have been set:
• **P029900 Turbocharger Underboost.
• P061B00 Internal Control Module Torque Calculation Performance.
• P046100 Fuel Level Sensor 1 Performance.**
• P0506 Idle Control System RPM Lower Than Expected.
• P20EE00 NOx Catalyst Efficiency Below Threshold.
• P242F00 Diesel Particulate Filter Restriction Ash Accumulation.
• P145100 Diesel Particulate Filter System Performance.
• P246300 Diesel Particulate Filter Restriction Soot Accumulation Bank 1.
• P026B Injection Timing Performance.
• P060700 ECU Internal Performance.
• P20E800 Reductant Pressure Too Low.
• P030100 Cylinder1 Misfire.
• P030200 Cylinder 2 Misfire.
• P030300 Cylinder 3 Misfire.
• P030400 Cylinder 4 Misfire.
• P030500 Cylinder 5 Misfire.
• P030600 Cylinder 6 Misfire.
• P1C5400 SCR NOx Catalyst Missing.
• P270600 MS Solenoid Circuit (68RFE Only).
• P1D7300 AGS Performance.
• P24A500 EGR Cooler Bypass Bank 1 Control Stuck (Sales Code ETM).
• P042000 Catalyst System Efficiency Below Threshold Bank 1 (Sales Code ETM).
• P200200 Diesel Particulate Filter Efficiency Below Threshold (Sales Code ETM).
• P019100 Fuel Rail Pressure Sensor Circuit Performance (Sales Code ETM).
• P040100 EGR System Performance (Sales Code ETM).
• P208B00 Reductant Pump 1 Control Performance (Sales Code ETM).
• **Transmission overheat protection (DG7 Only).**
• Adaptive Cruise improvements at high altitude.
• Ambient Air Pressure displayed correctly in wiTECH.
• Oil pressure switch modification.
• Engine Warmup Protection Improvement to help promote better oil delivery to engine bearings
during cold starts.
cycle.
• Idle Instability.
• Idle fluctuation.
This bulletin supersedes Technical Service Bulletin (TSB) 18-102-22 REV. A, date of issue August 10, 2022, which should be removed from your files. All revisions are highlighted with **asterisks** and include DTC, additional software enhancements and LOPS.
This Technical Service Bulletin (TSB) has also been released as a Rapid Service Update (RSU) 21027, date of issue March 05, 2021. All applicable RSU VINs have been loaded. To verify this RSU service action is applicable to the vehicle, use VIP or perform a VIN search in DealerCONNECT/Service Library. All repairs are reimbursable within the provisions of warranty. This RSU will expire 18 months after the date of issue.
NOTE: This calibration update is only for vehicles that have had the updated CP3.3 design High Pressure Fuel Injection Pump installed. All other calibrations to support the CP4 design pump have been deactivated. DO NOT perform this calibration update unless recall Y78 has been performed first.
  • 18-067-23.pdf
