Customers may experience a Malfunction Indicator Lamp (MIL) illumination. Upon further investigation
the technician may find that one or more of the following Diagnostic Trouble Codes (DTCs) have been
set:
• **P0299 Turbocharger Underboost.**
• P026B00 Injection Timing Performance.
• P061B00 Internal Control Module Torque Calculation Performance.
• P145100 Diesel Particulate Filter System Performance.
• P075500 Shift Solenoid “B” (DG7 Trans Sales Code). [mod: 68RFE]
• P076500 Shift Solenoid ”D“(DG7 Only).
• P040100 EGR System Performance
Customers may also experience the following:
• **Service Exhaust System message in the Electronic Vehicle Information Center (EVIC) with no MIL.**
• Improvements to cold temperature engine rpm fluctuation.
• Reduce audible engine flare during upshifts (DG7 Only).
• Improvements to help prevent OD clutch premature wear (DG7 Only).
• 1-2-1 gear hunting on grades while operating under high loads in areas of low traction (e.g. rain, snow, ice or dirt) (DG7 Only).
• wiTECH Fuel System RunUp Test routine Improvement.
• Idle stability Improvement.
• wiTECH PCM data improvements.
• wiTECH cylinder cutout routine, improvement.
