True ground clearance with 35's and 37's
areuriding
Sep 26, 2022
I'm trying to get a true measurement of ground clearance on the PW with both 35's and 37's. Anyone have this? I know I can add the difference to get the answer, but I wanted to see if anyone has actually gotten true measurements of ground clearance.
Crusty old shellback
Apr 10, 2021
It's going to be different from tire manufacture to tire manufacture. Also will depend on tire pressure.
Are you looking for a particular tire?
And everyone who responds should measure at the same spot. Say bottom of the diff front and rear.
jadmt
Aug 29, 2020
Age
65
Missoula
on my 2020 Toyo 35x12.5-17 mid 30's psi just a fraction under 10" at the front diff parked on smooth cement.
elephantrider
Hydraulic Lifter Crew
Sep 3, 2019
11" to bottom of front diff. I'm running 3" carli fronts with a modular bumper and a 13k winch.
areuriding
Sep 26, 2022
Where the hell did this guy get his info from??
The end result is 14.2 inches of ground clearance – up 1.1 inches over lesser Ram 2500 4x4s and 2.2 inches more than the Raptor – as well as handy off-road features like a disconnecting front sway bar, locking front and rear differentials, and a standard front winch.
Email: brett.evans@motor1.com
Occupation: Senior Editor
Vehicle Model Date: 2022
elephantrider
Sep 3, 2019
I like the frame measurements. i got almost 22" of clearance, clarance! :D
PMC
Feb 15, 2021
My Carli front diff cover is just over 10" with Mickey Thompson Baja Legend MTZ 37" tires. Frame sits at 22" with Carli Pin-top.
Apr 10, 2021
'21 Power Wagon. BFG 35x12.50 17vl on stock beadlock rims.
45/37 PSI.
10" F/ 8" R at bottom of diff.
