Jimmy Dean
What are your recommendations for a travel trailer hitch? Eventually plan on a toy hauler.
Bumper pull or 5th wheel?What are your recommendations for a travel trailer hitch? Eventually plan on a toy hauler.
Sent from my SM-S918U using Tapatalk
I also like the Anderson WDH. Quiet, no buck, no sway, easy to move around. I'm using with a 10k TT and it works great.
I like the equal-I-zer setup. It’s stout, which is important to me since I do a lot of back road travel with mine. It’s does a great job of transferring weight and isn’t too hard to setup. They have a model rated up to 16K, if I needed more I would look at the Blue Ox.
I wouldn’t focus on the anti-sway portion of a hitch, but rather the effectiveness of weight transfer. The only real way to eliminate sway is proper tongue weight. Don’t fall for the expensive hitches, they simply aren’t needed with a properly built and loaded trailer.
I personally wouldn’t run an Andersen “WDH” if it was free. There isn’t any good weight transferring physics behind its design. You don’t pick a wheelbarrow up by pulling the handles towards you, so why would you want to transfer weight that way.
Bottom line is that there are lots of options, and even more opinions. Get some ideas and do your own research.
I've never seen somebody so consistently post such bad information.
You sound like you drink a lot of kool-aide and do zero independent thinking or research...
Then again, that was already known with your purchase history.
Let me add it up for you:
- you think air bags are better than WDH
- you think adding air bags won't lighten your front end
- you don't have a clue how the Andersen distributes weight
- you think WDH's don't need to control for sway
Well I tried to distract them
Please show me that quote. I don't beleive that in the slightest.
They do completely different things, and I have said numerous times that they work well together. I use both all the time when towing a TT, and will continue to do so.
It won't, but I'd love to hear why you think air bags will lighten the front end.
Quite the opposite. Physics is physics, maybe you should take a Physics 101 class?
They don't, that's simple. Sway is generally a function of either insufficient tongue weight, or an improperly built trailer. There are other things that can cause sway, but they aren't as common and I would hate to confuse you.
If you are experiencing sway and you "fix" it with any hitch then all you did was mask it, not fix it. Fix the issue, don't cover it up.
Even seen a playground teeter totter? Two little kids on each end, uncompressable pivot in the middle. The fatter kid will raise the lighter kid. Now replace the pivot with a light spring; both kids hop on, they both sink when the pivot compresses.
That's whats happening when hooking up a TT. The rear axle/suspension is the pivot point, the two fat kids are your engine on the front and your tongue weight on the rear. The stiffer you make that rear suspension/pivot point (by adding air bags or sumo springs or timbrens), the more liable the front end is to wiggle off the ground.
A properly loaded trailer is the first step in fixing sway, but long trailers will still sway in heavy winds and by long heavy trucks.
No. You can fix sway by tweaking several different things, tongue weight is obviously crucial but after that a proper sway control hitch is critical for 25+ long trailers.
The husky centerline style of WDH reduces sway through the use of friction, as the bars slide across the bracket that holds them in place. The Andersen does not allow the trailer coupler to turn on the ball, instead the Anderson ball locks to the coupler and the ball itself moves inside the receiver, though movement is also there reduced through the use of friction.
The ProPride moves the horizontal pivot point over your axle, which eliminates sway completely.
