Thanks for the responses my tranny is 68rfe the highest it got was 212 degrees then cooled off rite away should I be concerned with this temp
Anything under 230 is fine for the 68RFE if it was 230-270 i would be worried and over 270 the trans fluid is burnt and the trans is toastThanks for the responses my tranny is 68rfe the highest it got was 212 degrees then cooled off rite away should I be concerned with this temp
85 degree weather uphill at about 65 mph for 3 miles pulling a 9500# 40ft camper once I got to top two miles down road cooled off to 190s usually stays between 190 and 200 is this ok
Coolant should normally run 215-218° when towing heavy, but it may creep up to 220-225°. Cummins lists 225° as the max allowable temp for the 190° thermostat, but Ram lists it as 245°… I personally haven’t seen above 220° on either of my HO 6.7’s, even when pushed hard on hot days. 210-215° is where mine normally runs when towing on flats and smaller grades.
The cooling fan doesn't even work hard enough to be heard until the 217* or so range. It becomes a loud bitch around 220 and will bring 225+ temps back down to the 2-teens in a hurry.
I don't buy the 225 "max" from cummins. That is artificially low.
Also, if you haven't seen over 220, you haven't worked the truck hard enough or in hot enough climates.
224 isn't enough to bother me, OP. Ive seen 224 plenty of times in 115* heat towing 14k lbs through the northern Nevada mountains in July. That fan will ensure you don't hurt the motor.
What is temp running on transmission when pulling do u recommend using tow haul buttonThe cooling fan doesn't even work hard enough to be heard until the 217* or so range. It becomes a loud bitch around 220 and will bring 225+ temps back down to the 2-teens in a hurry.
If i am towing anything more than my single axle utility trailer, I use tow/haul.What is temp running on transmission when pulling do u recommend using tow haul button
The fan is commanded to 100% by 218° so there shouldn't be much, if any, increase in fan rpms above that if the fan clutch is working properly.
You're right.. Cummins doesn't know what they are talking about maybe you should go work for them and set them straight. It actually makes perfect sense, if you're that far above the fully open temp then the cooling system is inadequate for the heat being created by the engine.. either undersized or not working properly. It's about heat rejection and not what the motor can handle, the 180° thermostats have a max allowable of 212° and the 165° thermostats have a max allowable of 205°. Ram states 245° max, which is probably more inline with causing issues. If you're easily able to exceed 225° then it's probably time for some cooling system maintenance.
The hottest I've seen the truck isn't WOT on 100°+ days, it's 3/4 throttle where the rpms are lower. Downshift and the rpms come up and ECT's go down, WOT in those conditions does create more heat but also a lot more airflow from higher rpms.
Thanks for the science education, Sharpie. Maybe you should call Ram and tell them also since according to you, they say 245.
What does T/H add? I used to punch the button with big loads but after I forgot it a few times, and it has to be punched after every time you start the truck, I was at a loss for what good it was doing. Just shift strategy?WIth the Aisin, I haven't seen above 180 in those extreme environments.
If Im towing something light, I don't bother with T/H. If our 14k 5'er is hooked up, I run in T/H and let the truck do the thinking.
It seems like when I have a trailer hooked up, it's pretty much going to do what it's going to do anyway regardless of whether or not T/H is selected.
I got in the habit of punching the T/H button with Duramax because transmission temps would spike otherwise. I don't see that with the Aisin so honestly, I've just about quit worrying about the T/H button with my Ram.
Maybe I'm missing something. If it's just shift strategy, I'm good with it. But with the exhaust brake selected, the truck utilizes the more aggressive downshift strategy when off the throttle whether or not T/H is selected or not. I never turn the EB off and it does not have be continually selected, it stays on.
